[GRASS-QA] GRASS QA: carlos | ./grass6/raster/r.grow2/main.c |no
clones | 0 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Oct 2 11:57:24 EDT 2007
Hello carlos,
ANALYSIS
raster/r.grow2/main.c functions
distance_euclidian_squared (Begins at: 35 Ends at: 38)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
distance_maximum (Begins at: 40 Ends at: 43)
CalledNBR: | 4 | | OK |
LOC: | 4 | | OK |
metrics are OK
distance_manhattan (Begins at: 45 Ends at: 48)
CalledNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
setup_neighbors (Begins at: 50 Ends at: 78)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
LOC: | 29 | | OK |
metrics are OK
setup_neighbors_euclidian (Begins at: 80 Ends at: 85)
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
setup_neighbors_maximum (Begins at: 87 Ends at: 90)
LOC: | 4 | | OK |
metrics are OK
setup_neighbors_manhattan (Begins at: 92 Ends at: 95)
LOC: | 4 | | OK |
metrics are OK
main (Begins at: 97 Ends at: 316)
Complexity: | 26 | ** | Warning |
CalledNBR: | 71 | ** | Warning |
LOC: | 220 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-02 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
