[GRASS-QA] GRASS QA: martinl | ./grass6/db/base/execute.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 10 05:13:22 EDT 2007
Hello martinl,
ANALYSIS
db/base/execute.c functions
main (Begins at: 32 Ends at: 87)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 56 | | OK |
metrics are OK
parse_command_line (Begins at: 89 Ends at: 128)
Complexity: | 4 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 40 | | OK |
metrics are OK
get_stmt (Begins at: 131 Ends at: 157)
CalledNBR: | 8 | | OK |
LOC: | 27 | | OK |
metrics are OK
stmt_is_empty (Begins at: 160 Ends at: 165)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
