[GRASS-QA] GRASS QA: glynn |
./grass6/lib/db/dbmi_base/xdrprocedure.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Oct 15 02:56:50 EDT 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_base/xdrprocedure.c functions
db__start_procedure_call (Begins at: 7 Ends at: 27)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 21 | | OK |
metrics are OK
db__recv_procnum (Begins at: 36 Ends at: 49)
Complexity: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
db__send_procedure_ok (Begins at: 52 Ends at: 55)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
db__send_procedure_not_implemented (Begins at: 58 Ends at: 61)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
