[GRASS-QA] GRASS QA: glynn | ./grass6/lib/db/dbmi_base/xdrint.c |2
clones ( xdrchar.c xdrdouble.c xdrfloat.c xdrint.c )| 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Oct 15 02:56:50 EDT 2007
Hello glynn,
ANALYSIS
lib/db/dbmi_base/xdrint.c functions
db__send_int (Begins at: 6 Ends at: 21)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 16 | | OK |
metrics are OK
db__recv_int (Begins at: 24 Ends at: 40)
LOC: | 17 | | OK |
metrics are OK
db__send_int_array (Begins at: 43 Ends at: 66)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 24 | | OK |
metrics are OK
db__recv_int_array (Begins at: 71 Ends at: 120)
Complexity: | 10 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 50 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
db__send_int db__recv_int_array
In lib/db/dbmi_base/xdrint.c clones of db__send_int are:
lib/db/dbmi_base/xdrfloat.c db__send_float
lib/db/dbmi_base/xdrdouble.c db__recv_double
lib/db/dbmi_base/xdrchar.c db__recv_char
In lib/db/dbmi_base/xdrint.c clones of db__recv_int_array are:
lib/db/dbmi_base/xdrshort.c db__recv_short_array
Threshold GRASS6 key metrics values at 2007-10-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
