[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.random/count.c |2 clones ( count.c )| 0 monsters | 0 warnings
Tue Oct 16 08:31:04 EDT 2007
Hello markus,
ANALYSIS
raster/r.random/count.c functions
get_stats (Begins at: 18 Ends at: 85)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      30 |       |      OK |
LOC:          |      68 |       |      OK |
metrics are OK
set_min (Begins at: 88 Ends at: 114)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
set_max (Begins at: 117 Ends at: 143)
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  set_max  set_min
In raster/r.random/count.c clones of  set_max are:
	raster/r.random/count.c  set_min
In raster/r.random/count.c clones of  set_min are:
	raster/r.random/count.c  set_max
Threshold GRASS6 key metrics values at 2007-10-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
