[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.random/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Oct 16 08:31:05 EDT 2007
Hello markus,
ANALYSIS
raster/r.random/main.c functions
main (Begins at: 30 Ends at: 172)
Complexity: | 17 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 47 | * | |
LOC: | 143 | * | |
metrics are OK
has_percent (Begins at: 175 Ends at: 182)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
