[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.random/random.c |no clones | 0 monsters | 1 warnings
Tue Oct 16 08:31:05 EDT 2007
Hello markus,
ANALYSIS
raster/r.random/random.c functions
execute_random (Begins at: 15 Ends at: 191)
Complexity:   |      24 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      75 |    ** | Warning |
LOC:          |     177 |     * |         |
at least 1 values are close to an outlier please consider revising code
cpvalue (Begins at: 194 Ends at: 206)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
cell_as_dbl (Begins at: 209 Ends at: 222)
LOC:          |      14 |       |      OK |
metrics are OK
set_to_null (Begins at: 225 Ends at: 236)
CalledNBR:    |       3 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
is_null_value (Begins at: 240 Ends at: 256)
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
