[GRASS-QA] GRASS QA: robertoa |
./grass6/vector/lidar/lidarlib/zones.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Oct 19 10:50:15 EDT 2007
Hello robertoa,
ANALYSIS
vector/lidar/lidarlib/zones.c functions
P_zero_dim (Begins at: 15 Ends at: 22)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
P_set_regions (Begins at: 26 Ends at: 85)
Complexity: | 8 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 1 | | OK |
LOC: | 60 | | OK |
metrics are OK
P_get_orlo (Begins at: 89 Ends at: 103)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 15 | | OK |
metrics are OK
P_get_BandWidth (Begins at: 107 Ends at: 116)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
P_Mean_Calc (Begins at: 120 Ends at: 143)
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 24 | | OK |
metrics are OK
P_Read_Vector_Region_Map (Begins at: 147 Ends at: 200)
Complexity: | 5 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 54 | | OK |
metrics are OK
P_Create_Aux_Table (Begins at: 204 Ends at: 229)
CalledNBR: | 14 | | OK |
LOC: | 26 | | OK |
metrics are OK
P_Drop_Aux_Table (Begins at: 232 Ends at: 239)
CalledNBR: | 4 | | OK |
LOC: | 8 | | OK |
metrics are OK
P_Aux_to_Raster (Begins at: 242 Ends at: 264)
LOC: | 23 | | OK |
metrics are OK
P_Aux_to_Vector (Begins at: 268 Ends at: 323)
Complexity: | 4 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 56 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
