[GRASS-QA] GRASS QA: robertoa |
./grass6/vector/lidar/v.lidar.edgedetection/edgedetection.c
|no clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Oct 19 10:50:15 EDT 2007
Hello robertoa,
ANALYSIS
vector/lidar/v.lidar.edgedetection/edgedetection.c functions
edge_detection (Begins at: 35 Ends at: 113)
Complexity: | 7 | | OK |
ParamNBR: | 10 | *** | MONSTER |
CalledNBR: | 32 | | OK |
LOC: | 79 | | OK |
1 metric are OUT OF RANGE!
Get_Gradient (Begins at: 115 Ends at: 137)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 23 | | OK |
metrics are OK
classification (Begins at: 139 Ends at: 309)
Complexity: | 24 | * | |
ParamNBR: | 16 | *** | MONSTER |
CalledNBR: | 61 | ** | Warning |
LOC: | 171 | * | |
Insert (Begins at: 311 Ends at: 324)
ParamNBR: | 5 | * | |
CalledNBR: | 6 | | OK |
LOC: | 14 | | OK |
metrics are OK
Insert_Interpolation (Begins at: 326 Ends at: 339)
LOC: | 14 | | OK |
metrics are OK
UpDate (Begins at: 342 Ends at: 354)
CalledNBR: | 4 | | OK |
LOC: | 13 | | OK |
metrics are OK
Select (Begins at: 356 Ends at: 398)
Complexity: | 6 | | OK |
CalledNBR: | 22 | | OK |
LOC: | 43 | | OK |
metrics are OK
Create_AuxEdge_Table (Begins at: 401 Ends at: 434)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 34 | | OK |
metrics are OK
Drop_Aux_Table (Begins at: 436 Ends at: 445)
LOC: | 10 | | OK |
metrics are OK
Create_Interpolation_Table (Begins at: 448 Ends at: 474)
ParamNBR: | 2 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 27 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
