[GRASS-QA] GRASS QA: cho | ./grass6/raster/r.stats/stats.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Oct 24 17:26:17 EDT 2007
Hello cho,
ANALYSIS
raster/r.stats/stats.c functions
initialize_cell_stats (Begins at: 32 Ends at: 53)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 22 | | OK |
metrics are OK
allocate_values (Begins at: 56 Ends at: 63)
CalledNBR: | 1 | | OK |
LOC: | 8 | | OK |
metrics are OK
NewNode (Begins at: 66 Ends at: 88)
Complexity: | 3 | | OK |
LOC: | 23 | | OK |
metrics are OK
reset_null_vals (Begins at: 91 Ends at: 100)
ParamNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
update_cell_stats (Begins at: 102 Ends at: 166)
Complexity: | 10 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 65 | | OK |
metrics are OK
node_compare (Begins at: 169 Ends at: 180)
Complexity: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 12 | | OK |
metrics are OK
sort_cell_stats (Begins at: 182 Ends at: 196)
LOC: | 15 | | OK |
metrics are OK
print_node_count (Begins at: 199 Ends at: 204)
LOC: | 6 | | OK |
metrics are OK
print_cell_stats (Begins at: 207 Ends at: 327)
Complexity: | 22 | * | |
ParamNBR: | 6 | * | |
CalledNBR: | 36 | * | |
LOC: | 121 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-10-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
