[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/break_lines.c |no clones | 0 monsters | 3 warnings
Thu Oct 25 03:56:59 EDT 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/break_lines.c functions
Vect_break_lines (Begins at: 37 Ends at: 278)
Complexity:   |      37 |   *** | MONSTER |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     242 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
