[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/snap.c |no clones | 1 monsters | 0 warnings
Thu Oct 25 03:56:59 EDT 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/snap.c functions
add_item (Begins at: 57 Ends at: 94)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Vect_snap_lines_list (Begins at: 97 Ends at: 403)
Complexity:   |      28 |    ** | Warning |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      75 |    ** | Warning |
LOC:          |     307 |   *** | MONSTER |
1 metric are OUT OF RANGE!
sort_new (Begins at: 406 Ends at: 428)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
Vect_snap_lines (Begins at: 431 Ends at: 467)
CalledNBR:    |      12 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
