[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.stats/raw_stats.c |no clones | 0 monsters | 0 warnings
Thu Oct 25 11:50:07 EDT 2007
Hello markus,
ANALYSIS
raster/r.stats/raw_stats.c functions
raw_stats (Begins at: 6 Ends at: 118)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      35 |       |      OK |
LOC:          |     113 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
