[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.stats/stats.c |no clones | 0 monsters | 0 warnings
Thu Oct 25 11:50:07 EDT 2007
Hello markus,
ANALYSIS
raster/r.stats/stats.c functions
initialize_cell_stats (Begins at: 32 Ends at: 53)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
allocate_values (Begins at: 56 Ends at: 63)
CalledNBR:    |       1 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
NewNode (Begins at: 66 Ends at: 88)
Complexity:   |       3 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
reset_null_vals (Begins at: 91 Ends at: 100)
LOC:          |      10 |       |      OK |
metrics are OK
update_cell_stats (Begins at: 102 Ends at: 166)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
node_compare (Begins at: 169 Ends at: 180)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
sort_cell_stats (Begins at: 182 Ends at: 196)
LOC:          |      15 |       |      OK |
metrics are OK
print_node_count (Begins at: 199 Ends at: 204)
LOC:          |       6 |       |      OK |
metrics are OK
print_cell_stats (Begins at: 207 Ends at: 327)
Complexity:   |      22 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      36 |     * |         |
LOC:          |     121 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
