[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.los/mark_pts.c |no clones | 0 monsters | 0 warnings
Wed Oct 31 02:50:21 EDT 2007
Hello hamish,
ANALYSIS
raster/r.los/mark_pts.c functions
mark_visible_points (Begins at: 20 Ends at: 45)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-31 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
