[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.los/make_list.c |no clones | 0 monsters | 1 warnings
Wed Oct 31 02:50:21 EDT 2007
Hello hamish,
ANALYSIS
raster/r.los/make_list.c functions
make_list (Begins at: 19 Ends at: 57)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |       7 |       |      OK |
LOC:          |      39 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-10-31 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
