[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.to.db/query.c |no clones | 0 monsters | 1 warnings
Sat Sep 1 17:59:03 EDT 2007
Hello carlos,
ANALYSIS
vector/v.to.db/query.c functions
query (Begins at: 10 Ends at: 173)
Complexity:   |      23 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     164 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-01 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
