[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.sample/main.c |no clones | 1 monsters | 0 warnings
Sat Sep 1 18:07:07 EDT 2007
Hello carlos,
ANALYSIS
vector/v.sample/main.c functions
main (Begins at: 51 Ends at: 293)
Complexity:   |      24 |     * |         |
CalledNBR:    |     109 |   *** | MONSTER |
LOC:          |     243 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-01 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
