[GRASS-QA] GRASS QA: martinl |
./grass6/vector/v.transform/trans_digit.c |no clones | 0
monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 7 06:45:46 EDT 2007
Hello martinl,
ANALYSIS
vector/v.transform/trans_digit.c functions
transform_digit_file (Begins at: 31 Ends at: 157)
Complexity: | 20 | * | |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 28 | | OK |
LOC: | 127 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-09-07 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
