[GRASS-QA] GRASS QA: martinl | ./grass6/lib/gis/parser.c |no clones
| 3 monsters | 4 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 7 09:07:35 EDT 2007
Hello martinl,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 162 Ends at: 183)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 22 | | OK |
metrics are OK
G_define_flag (Begins at: 186 Ends at: 244)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 59 | | OK |
metrics are OK
G_define_option (Begins at: 247 Ends at: 329)
LOC: | 83 | | OK |
metrics are OK
G_define_standard_option (Begins at: 332 Ends at: 611)
Complexity: | 32 | ** | Warning |
CalledNBR: | 37 | * | |
LOC: | 280 | *** | MONSTER |
1 metric are OUT OF RANGE!
G_define_module (Begins at: 614 Ends at: 666)
CalledNBR: | 1 | | OK |
LOC: | 53 | | OK |
metrics are OK
G_parser (Begins at: 668 Ends at: 937)
Complexity: | 38 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 78 | ** | Warning |
LOC: | 270 | ** | Warning |
uses_new_gisprompt (Begins at: 940 Ends at: 990)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 51 | | OK |
metrics are OK
G_usage (Begins at: 992 Ends at: 1178)
Complexity: | 33 | ** | Warning |
CalledNBR: | 53 | * | |
LOC: | 187 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1180 Ends at: 1196)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
print_escaped_for_html (Begins at: 1203 Ends at: 1214)
Complexity: | 7 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 12 | | OK |
metrics are OK
G_usage_xml (Begins at: 1217 Ends at: 1431)
Complexity: | 28 | ** | Warning |
CalledNBR: | 71 | ** | Warning |
LOC: | 215 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
G_usage_html (Begins at: 1433 Ends at: 1658)
Complexity: | 42 | *** | MONSTER |
CalledNBR: | 85 | ** | Warning |
LOC: | 226 | ** | Warning |
G_script (Begins at: 1660 Ends at: 1771)
Complexity: | 22 | * | |
CalledNBR: | 46 | * | |
LOC: | 112 | | OK |
metrics are OK
generate_tcl (Begins at: 1773 Ends at: 1868)
Complexity: | 10 | | OK |
CalledNBR: | 45 | * | |
LOC: | 96 | | OK |
metrics are OK
G_gui_tcltk (Begins at: 1871 Ends at: 1900)
CalledNBR: | 8 | | OK |
LOC: | 30 | | OK |
metrics are OK
G_gui_wx (Begins at: 1903 Ends at: 1914)
LOC: | 12 | | OK |
metrics are OK
G_gui (Begins at: 1917 Ends at: 1925)
Complexity: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
G_tcltk (Begins at: 1928 Ends at: 1943)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1945 Ends at: 1975)
Complexity: | 4 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 31 | | OK |
metrics are OK
show (Begins at: 1977 Ends at: 1990)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1992 Ends at: 2019)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 2024 Ends at: 2033)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 2035 Ends at: 2095)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 2097 Ends at: 2134)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 2136 Ends at: 2178)
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 2180 Ends at: 2246)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 2248 Ends at: 2288)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 2290 Ends at: 2317)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 2319 Ends at: 2342)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 2344 Ends at: 2407)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 2409 Ends at: 2447)
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 2450 Ends at: 2506)
Complexity: | 11 | | OK |
LOC: | 57 | | OK |
metrics are OK
interactive (Begins at: 2508 Ends at: 2536)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2538 Ends at: 2546)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2548 Ends at: 2638)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2640 Ends at: 2670)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2672 Ends at: 2729)
CalledNBR: | 20 | | OK |
LOC: | 58 | | OK |
metrics are OK
G_recreate_command (Begins at: 2731 Ends at: 2833)
CalledNBR: | 25 | | OK |
LOC: | 103 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-09-07 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
