[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.report/parse.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Sep 30 03:17:27 EDT 2007
Hello martinl,
ANALYSIS
raster/r.report/parse.c functions
parse_command_line (Begins at: 6 Ends at: 204)
Complexity: | 13 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 58 | * | |
LOC: | 199 | ** | Warning |
at least 1 values are close to an outlier please consider revising code
parse_units (Begins at: 206 Ends at: 241)
Complexity: | 10 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 36 | | OK |
metrics are OK
parse_layer (Begins at: 243 Ends at: 288)
Complexity: | 6 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 46 | | OK |
metrics are OK
match (Begins at: 290 Ends at: 297)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-09-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
