[GRASS-QA] GRASS QA: martinl |
./grass6/raster/r.report/prt_report.c |no clones | 0 monsters
| 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Sep 30 03:17:27 EDT 2007
Hello martinl,
ANALYSIS
raster/r.report/prt_report.c functions
print_report (Begins at: 5 Ends at: 274)
Complexity: | 28 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 37 | * | |
LOC: | 270 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
construct_val_str (Begins at: 276 Ends at: 308)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 33 | | OK |
metrics are OK
construct_cat_label (Begins at: 310 Ends at: 338)
CalledNBR: | 7 | | OK |
LOC: | 29 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-09-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
