[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.report/stats.c |no clones | 0 monsters | 0 warnings
Sun Sep 30 03:17:27 EDT 2007
Hello martinl,
ANALYSIS
raster/r.report/stats.c functions
get_stats (Begins at: 9 Ends at: 95)
Complexity:   |      21 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      38 |     * |         |
LOC:          |      87 |       |      OK |
metrics are OK
die (Begins at: 97 Ends at: 102)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
