[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.buffer/main.c |1
clones ( main.c )| 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Sep 30 06:56:04 EDT 2007
Hello carlos,
ANALYSIS
vector/v.buffer/main.c functions
input_distance (Begins at: 35 Ends at: 121)
Complexity: | 14 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 16 | | OK |
LOC: | 87 | | OK |
metrics are OK
area_in_buffer (Begins at: 128 Ends at: 207)
Complexity: | 8 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 15 | | OK |
LOC: | 80 | | OK |
metrics are OK
stop (Begins at: 209 Ends at: 217)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 9 | | OK |
metrics are OK
main (Begins at: 220 Ends at: 714)
Complexity: | 56 | *** | MONSTER |
CalledNBR: | 190 | *** | MONSTER |
LOC: | 495 | *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
stop
In vector/v.buffer/main.c clones of stop are:
raster/r.carve/vect.c open_new_vect
Threshold GRASS6 key metrics values at 2007-09-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
