[GRASS-QA] GRASS QA: carlos | ./grass6/display/d.colortable/main.c
|no clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Sep 30 08:01:16 EDT 2007
Hello carlos,
ANALYSIS
display/d.colortable/main.c functions
main (Begins at: 29 Ends at: 282)
Complexity: | 24 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 74 | ** | Warning |
LOC: | 254 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-09-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 88 |
LOC: 43 | 195 | 273 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
