[GRASS-QA] GRASS QA: glynn |get_ellipse.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Dec 10 22:44:06 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/gis/get_ellipse.c
          Function
compare_table_names(Begins at: 255, Ends at:261)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       7 |       |           OK |         7 |
Conclusion:   | this function is a            OK           |
metrics are OK
ellipsoid_table_file(Begins at: 249, Ends at:253)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
get_a_e2_f(Begins at: 208, Ends at:247)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      40 |       |           OK |        40 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
get_ellipsoid_parameters(Begins at: 341, Ends at:406)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      21 |     * |      WARNING |        21 |
LOC:          |      66 |     * |      WARNING |        66 |
 at least 4 values are close to an outlier please consider revising code!
G_ellipsoid_description(Begins at: 202, Ends at:206)
metrics are OK
G_ellipsoid_name(Begins at: 138, Ends at:142)
metrics are OK
G_get_ellipsoid_by_name(Begins at: 110, Ends at:124)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      15 |       |           OK |        15 |
 at least 1 values are close to an outlier please consider revising code!
G_get_ellipsoid_parameters(Begins at: 66, Ends at:94)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      29 |       |           OK |        29 |
metrics are OK
G_get_spheroid_by_name(Begins at: 171, Ends at:186)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      16 |       |           OK |        16 |
read_ellipsoid_table(Begins at: 263, Ends at:339)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      26 |    ** | BABY-MONSTER |        26 |
LOC:          |      77 |     * |      WARNING |        77 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Dec 10 23:10:11 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
