[GRASS-QA] GRASS QA: martinl |get_ellipse.c | no clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Wed Dec 10 22:47:13 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/gis/get_ellipse.c
Function
compare_table_names(Begins at: 255, Ends at:261)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
Conclusion: | this function is a OK |
metrics are OK
ellipsoid_table_file(Begins at: 249, Ends at:253)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 5 | | OK | 5 |
metrics are OK
get_a_e2_f(Begins at: 208, Ends at:247)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 40 | | OK | 40 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
get_ellipsoid_parameters(Begins at: 343, Ends at:409)
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 67 | * | WARNING | 67 |
at least 4 values are close to an outlier please consider revising code!
G_ellipsoid_description(Begins at: 202, Ends at:206)
metrics are OK
G_ellipsoid_name(Begins at: 138, Ends at:142)
metrics are OK
G_get_ellipsoid_by_name(Begins at: 110, Ends at:124)
Complexity: | 3 | | OK | 3 |
LOC: | 15 | | OK | 15 |
at least 1 values are close to an outlier please consider revising code!
G_get_ellipsoid_parameters(Begins at: 66, Ends at:94)
CalledNBR: | 7 | | OK | 7 |
LOC: | 29 | | OK | 29 |
metrics are OK
G_get_spheroid_by_name(Begins at: 171, Ends at:186)
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 16 | | OK | 16 |
read_ellipsoid_table(Begins at: 263, Ends at:341)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 79 | * | WARNING | 79 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Dec 10 23:13:18 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
