[GRASS-QA] GRASS QA: glynn |main.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Dec 10 22:50:39 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.grow.distance/main.c
Function
check(Begins at: 84, Ends at:118)
| New Metrics |Old Metrics|
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 4 | * | WARNING | 3 |
CalledNBR: | 3 | | OK | 2 |
LOC: | 35 | | OK | 30 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
distance_euclidean_squared(Begins at: 41, Ends at:44)
Complexity: | 1 | | OK | |
ParamNBR: | 2 | | OK | |
CalledNBR: | 0 | | OK | |
LOC: | 4 | | OK | |
Conclusion: | this function is a OK |
metrics are OK
distance_euclidian_squared(Begins at: 39, Ends at:42)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
distance_manhattan(Begins at: 51, Ends at:54)
CalledNBR: | 2 | | OK | 2 |
metrics are OK
distance_maximum(Begins at: 46, Ends at:49)
Complexity: | 1 | *** | MONSTER | 1 |
CalledNBR: | 3 | *** | MONSTER | 3 |
LOC: | 4 | *** | MONSTER | 4 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
geodesic_distance(Begins at: 56, Ends at:64)
ParamNBR: | 4 | | OK | |
CalledNBR: | 5 | | OK | |
LOC: | 9 | | OK | |
metrics are OK
main(Begins at: 120, Ends at:372)
Complexity: | 38 | | OK | 20 |
CalledNBR: | 101 | | OK | 73 |
LOC: | 253 | | OK | 181 |
metrics are OK
swap_rows(Begins at: 66, Ends at:82)
ParamNBR: | 1 | * | WARNING | 1 |
LOC: | 17 | | OK | 11 |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Dec 10 23:16:44 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
