[GRASS-QA] GRASS QA: neteler |convert.c | 2 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Dec 11 01:41:08 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/proj/convert.c
Function
DatumNameMassage(Begins at: 752, Ends at:793)
| New Metrics |Old Metrics|
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 42 | * | WARNING | 42 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
GPJ_grass_to_osr(Begins at: 86, Ends at:235)
Complexity: | 18 | ** | BABY-MONSTER | 18 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 67 | *** | MONSTER | 67 |
LOC: | 150 | *** | MONSTER | 150 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
GPJ_grass_to_wkt(Begins at: 52, Ends at:74)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 23 | | OK | 23 |
at least 1 values are close to an outlier please consider revising code!
GPJ_osr_to_grass(Begins at: 256, Ends at:641)
Complexity: | 44 | *** | MONSTER | 44 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 98 | *** | MONSTER | 98 |
LOC: | 386 | *** | MONSTER | 386 |
GPJ_set_csv_loc(Begins at: 691, Ends at:702)
Complexity: | 2 | | OK | 2 |
LOC: | 12 | | OK | 12 |
Conclusion: | this function is a OK |
metrics are OK
GPJ_wkt_to_grass(Begins at: 663, Ends at:685)
Clone analysis:
This file has 2 potentially cloned functions:
Nviz_color_from_str
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/proj/convert.c clones of GPJ_set_csv_loc are:
/tmp/grassSVN/grass-addons/visualization/nviz2/lib/nviz.c Nviz_color_from_str
/var/project-manager/grass/grassSVN/grass-addons/visualization/nviz2/lib/nviz.c Nviz_color_from_str
____________________________________________
Threshold grass key metrics values at Thu Dec 11 02:07:15 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
