[GRASS-QA] GRASS QA: neteler |convert.c | 2 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 01:43:41 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/proj/convert.c
          Function
DatumNameMassage(Begins at: 748, Ends at:789)
              |          New Metrics           |Old Metrics|
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      42 |     * |      WARNING |        42 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
GPJ_grass_to_osr(Begins at: 86, Ends at:235)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      67 |   *** |      MONSTER |        67 |
LOC:          |     150 |   *** |      MONSTER |       150 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
GPJ_grass_to_wkt(Begins at: 52, Ends at:74)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      23 |       |           OK |        23 |
 at least 1 values are close to an outlier please consider revising code!
GPJ_osr_to_grass(Begins at: 256, Ends at:637)
Complexity:   |      44 |   *** |      MONSTER |        44 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      98 |   *** |      MONSTER |        98 |
LOC:          |     382 |   *** |      MONSTER |       382 |
GPJ_set_csv_loc(Begins at: 687, Ends at:698)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |      12 |       |           OK |        12 |
Conclusion:   | this function is a            OK           |
metrics are OK
GPJ_wkt_to_grass(Begins at: 659, Ends at:681)
Clone analysis:
This file has 2 potentially cloned functions:
  Nviz_color_from_str
In /var/project-manager/grass/grassSVN/grass/trunk/lib/proj/convert.c clones of GPJ_set_csv_loc are:
          /tmp/grassSVN/grass-addons/visualization/nviz2/lib/nviz.c  Nviz_color_from_str
          /var/project-manager/grass/grassSVN/grass-addons/visualization/nviz2/lib/nviz.c  Nviz_color_from_str
____________________________________________
Threshold grass key metrics values at Thu Dec 11 02:09:48 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
