[GRASS-QA] GRASS QA: glynn |main.c main.c main.c main.c ...| 6 clones
| 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 02:20:59 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.flow/main.c
Function
add_to_line(Begins at: 160, Ends at:167)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 8 | | OK | 8 |
Conclusion: | this function is a OK |
metrics are OK
calculate(Begins at: 300, Ends at:399)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 30 | ** | BABY-MONSTER | 30 |
LOC: | 100 | ** | BABY-MONSTER | 100 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
height_angle_bounding_box(Begins at: 94, Ends at:136)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 43 | * | WARNING | 43 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
main(Begins at: 401, Ends at:592)
Complexity: | 12 | * | WARNING | 13 |
CalledNBR: | 71 | *** | MONSTER | 73 |
LOC: | 192 | *** | MONSTER | 194 |
Conclusion: | this function is a MONSTER |
next_point(Begins at: 198, Ends at:294)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 97 | ** | BABY-MONSTER | 97 |
on_map(Begins at: 147, Ends at:153)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 7 | | OK | 7 |
at least 1 values are close to an outlier please consider revising code!
rectify(Begins at: 172, Ends at:189)
Complexity: | 6 | * | WARNING | 6 |
LOC: | 18 | | OK | 18 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/raster/r.resamp.rst/main.c
Function
clean(Begins at: 577, Ends at:592)
Complexity: | 13 | * | WARNING | 13 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 16 | | OK | 16 |
clean_fatal_error(Begins at: 696, Ends at:723)
Complexity: | 7 | | OK | 7 |
CalledNBR: | 13 | | OK | 13 |
LOC: | 28 | | OK | 28 |
metrics are OK
create_temp_file(Begins at: 541, Ends at:563)
Complexity: | 5 | *** | MONSTER | 5 |
CalledNBR: | 9 | *** | MONSTER | 9 |
LOC: | 23 | *** | MONSTER | 23 |
create_temp_files(Begins at: 565, Ends at:575)
Complexity: | 1 | ** | BABY-MONSTER | 1 |
CalledNBR: | 8 | * | WARNING | 8 |
LOC: | 11 | | OK | 11 |
main(Begins at: 123, Ends at:539)
Complexity: | 44 | | OK | 45 |
CalledNBR: | 167 | | OK | 169 |
LOC: | 417 | | OK | 418 |
metrics are OK
Clone analysis:
File :grass/trunk/raster/r.sun/main.c
Function
brad(Begins at: 1494, Ends at:1521)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 4 | | OK | 4 |
metrics are OK
calculate(Begins at: 1192, Ends at:1468)
Complexity: | 47 | *** | MONSTER | 47 |
CalledNBR: | 71 | *** | MONSTER | 71 |
LOC: | 277 | *** | MONSTER | 277 |
com_declin(Begins at: 1482, Ends at:1492)
CalledNBR: | 3 | | OK | 3 |
metrics are OK
com_par(Begins at: 865, Ends at:936)
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 72 | * | WARNING | 72 |
com_par_const(Begins at: 825, Ends at:862)
CalledNBR: | 7 | | OK | 7 |
LOC: | 38 | | OK | 38 |
com_sol_const(Begins at: 1470, Ends at:1479)
CalledNBR: | 1 | | OK | 1 |
LOC: | 10 | | OK | 10 |
metrics are OK
cube(Begins at: 1153, Ends at:1158)
LOC: | 6 | | OK | 6 |
metrics are OK
distance(Begins at: 140, Ends at:149)
CalledNBR: | 2 | | OK | 2 |
drad(Begins at: 1523, Ends at:1577)
LOC: | 55 | * | WARNING | 55 |
INPUT(Begins at: 494, Ends at:690)
CalledNBR: | 74 | *** | MONSTER | 74 |
LOC: | 197 | *** | MONSTER | 197 |
joules2(Begins at: 980, Ends at:1110)
Complexity: | 22 | *** | MONSTER | 22 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 131 | ** | BABY-MONSTER | 131 |
lumcline2(Begins at: 940, Ends at:978)
Complexity: | 7 | * | WARNING | 7 |
LOC: | 39 | | OK | 39 |
main(Begins at: 152, Ends at:491)
Complexity: | 21 | *** | MONSTER | 22 |
CalledNBR: | 109 | *** | MONSTER | 110 |
LOC: | 340 | *** | MONSTER | 341 |
new_point(Begins at: 1115, Ends at:1124)
metrics are OK
OUTGR(Begins at: 692, Ends at:822)
Complexity: | 35 | *** | MONSTER | 35 |
CalledNBR: | 50 | *** | MONSTER | 50 |
searching(Begins at: 1160, Ends at:1186)
LOC: | 27 | | OK | 27 |
test(Begins at: 1579, Ends at:1593)
LOC: | 15 | | OK | 15 |
metrics are OK
where_is_point(Begins at: 1126, Ends at:1151)
LOC: | 26 | | OK | 26 |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
distance distance distance test test
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.sun/main.c clones of distance are:
/tmp/grassSVN/grass-addons/raster/r.sun_horizon/r.horizon/main.c distance
/tmp/grassSVN/grass-addons/raster/r.sun_horizon/r.sun2/main.c distance
/var/project-manager/grass/grassSVN/grass-addons/raster/r.sun_horizon/r.horizon/main.c distance
/var/project-manager/grass/grassSVN/grass-addons/raster/r.sun_horizon/r.sun2/main.c distance
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.sun/main.c clones of test are:
/tmp/grassSVN/grass-addons/raster/r.sun_horizon/r.sun2/main.c test
/var/project-manager/grass/grassSVN/grass-addons/raster/r.sun_horizon/r.sun2/main.c test
File :grass/trunk/vector/v.surf.rst/main.c
Function
clean_fatal_error(Begins at: 848, Ends at:875)
CalledNBR: | 13 | * | WARNING | 13 |
main(Begins at: 129, Ends at:802)
Complexity: | 99 | *** | MONSTER | 99 |
CalledNBR: | 291 | *** | MONSTER | 291 |
LOC: | 674 | *** | MONSTER | 674 |
print_tree(Begins at: 806, Ends at:844)
Clone analysis:
File :grass/trunk/vector/v.vol.rst/main.c
Function
main(Begins at: 194, Ends at:910)
Complexity: | 102 | *** | MONSTER | 102 |
CalledNBR: | 310 | *** | MONSTER | 310 |
LOC: | 717 | *** | MONSTER | 717 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 02:47:06 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
