[GRASS-QA] GRASS QA: glynn |gisdefs.h glocale.h clicker.c datum.c
...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 02:29:33 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/gisdefs.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/include/glocale.h
File :grass/trunk/lib/gis/clicker.c
Function
G_clicker(Begins at: 13, Ends at:29)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/gis/datum.c
Function
compare_table_names(Begins at: 195, Ends at:201)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
metrics are OK
G_datum_description(Begins at: 66, Ends at:74)
LOC: | 9 | | OK | 9 |
metrics are OK
G_datum_ellipsoid(Begins at: 76, Ends at:84)
metrics are OK
G_datum_name(Begins at: 56, Ends at:64)
metrics are OK
G_get_datumparams_from_projinfo(Begins at: 107, Ends at:142)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 36 | | OK | 36 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
G_get_datum_by_name(Begins at: 43, Ends at:54)
Complexity: | 3 | | OK | 3 |
LOC: | 12 | | OK | 12 |
metrics are OK
read_datum_table(Begins at: 144, Ends at:193)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 50 | * | WARNING | 50 |
Clone analysis:
File :grass/trunk/lib/gis/distance.c
Function
G_begin_distance_calculations(Begins at: 44, Ends at:62)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 19 | | OK | 19 |
metrics are OK
G_distance(Begins at: 78, Ends at:84)
ParamNBR: | 4 | * | WARNING | 4 |
at least 1 values are close to an outlier please consider revising code!
G_distance_between_line_segments(Begins at: 95, Ends at:114)
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 20 | | OK | 20 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
G_distance_point_to_line_segment(Begins at: 126, Ends at:174)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 49 | * | WARNING | 49 |
min2(Begins at: 181, Ends at:184)
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
min4(Begins at: 176, Ends at:179)
CalledNBR: | 3 | | OK | 3 |
Clone analysis:
File :grass/trunk/lib/gis/env.c
Function
get_env(Begins at: 182, Ends at:193)
metrics are OK
G_getenv(Begins at: 267, Ends at:276)
LOC: | 10 | | OK | 10 |
metrics are OK
G_getenv2(Begins at: 293, Ends at:302)
metrics are OK
G_get_gisrc_mode(Begins at: 71, Ends at:74)
metrics are OK
G_setenv(Begins at: 352, Ends at:358)
metrics are OK
G_setenv2(Begins at: 372, Ends at:378)
G_set_gisrc_mode(Begins at: 59, Ends at:62)
metrics are OK
G_unsetenv(Begins at: 420, Ends at:427)
LOC: | 8 | | OK | 8 |
metrics are OK
G_unsetenv2(Begins at: 438, Ends at:445)
metrics are OK
G__create_alt_env(Begins at: 537, Ends at:552)
LOC: | 16 | | OK | 16 |
metrics are OK
G__env_name(Begins at: 476, Ends at:486)
Complexity: | 4 | | OK | 4 |
LOC: | 11 | | OK | 11 |
metrics are OK
G__getenv(Begins at: 312, Ends at:320)
metrics are OK
G__getenv2(Begins at: 331, Ends at:339)
metrics are OK
G__get_gisrc_file(Begins at: 525, Ends at:528)
metrics are OK
G__read_env(Begins at: 495, Ends at:500)
LOC: | 6 | | OK | 6 |
metrics are OK
G__setenv(Begins at: 388, Ends at:393)
metrics are OK
G__setenv2(Begins at: 404, Ends at:409)
G__set_gisrc_file(Begins at: 509, Ends at:516)
metrics are OK
G__switch_env(Begins at: 561, Ends at:576)
metrics are OK
G__write_env(Begins at: 454, Ends at:460)
metrics are OK
open_env(Begins at: 233, Ends at:256)
CalledNBR: | 9 | | OK | 9 |
LOC: | 24 | | OK | 24 |
metrics are OK
read_env(Begins at: 76, Ends at:110)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 35 | | OK | 35 |
set_env(Begins at: 112, Ends at:165)
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 54 | * | WARNING | 54 |
at least 4 values are close to an outlier please consider revising code!
unset_env(Begins at: 167, Ends at:180)
LOC: | 14 | | OK | 14 |
metrics are OK
write_env(Begins at: 195, Ends at:207)
LOC: | 13 | | OK | 13 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/gdal.c
File :grass/trunk/lib/gis/geodesic.c
Function
adjust_lat(Begins at: 90, Ends at:98)
metrics are OK
adjust_lon(Begins at: 80, Ends at:88)
metrics are OK
G_begin_geodesic_equation(Begins at: 37, Ends at:68)
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 32 | | OK | 32 |
at least 2 values are close to an outlier please consider revising code!
G_geodesic_lat_from_lon(Begins at: 72, Ends at:78)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/geodist.c
Function
G_begin_geodesic_distance(Begins at: 52, Ends at:60)
metrics are OK
G_geodesic_distance(Begins at: 212, Ends at:217)
G_geodesic_distance_lon_to_lon(Begins at: 135, Ends at:196)
LOC: | 62 | * | WARNING | 62 |
G_set_geodesic_distance_lat1(Begins at: 75, Ends at:80)
metrics are OK
G_set_geodesic_distance_lat2(Begins at: 94, Ends at:119)
CalledNBR: | 7 | | OK | 7 |
LOC: | 26 | | OK | 26 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/get_ellipse.c
Function
compare_table_names(Begins at: 255, Ends at:261)
metrics are OK
ellipsoid_table_file(Begins at: 249, Ends at:253)
LOC: | 5 | | OK | 5 |
metrics are OK
get_a_e2_f(Begins at: 208, Ends at:247)
ParamNBR: | 5 | * | WARNING | 5 |
LOC: | 40 | | OK | 40 |
get_ellipsoid_parameters(Begins at: 341, Ends at:406)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 66 | * | WARNING | 66 |
G_ellipsoid_description(Begins at: 202, Ends at:206)
metrics are OK
G_ellipsoid_name(Begins at: 138, Ends at:142)
metrics are OK
G_get_ellipsoid_by_name(Begins at: 110, Ends at:124)
LOC: | 15 | | OK | 15 |
G_get_ellipsoid_parameters(Begins at: 66, Ends at:94)
LOC: | 29 | | OK | 29 |
metrics are OK
G_get_spheroid_by_name(Begins at: 171, Ends at:186)
read_ellipsoid_table(Begins at: 263, Ends at:339)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 77 | * | WARNING | 77 |
Clone analysis:
File :grass/trunk/lib/gis/locale.c
Function
G_gettext(Begins at: 53, Ends at:74)
LOC: | 22 | | OK | 22 |
metrics are OK
locale_dir(Begins at: 25, Ends at:41)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/ls.c
Function
cmp_names(Begins at: 32, Ends at:38)
metrics are OK
G_ls(Begins at: 94, Ends at:107)
metrics are OK
G_ls_format(Begins at: 124, Ends at:185)
G__ls(Begins at: 56, Ends at:80)
LOC: | 25 | | OK | 25 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/mapset_nme.c
Function
get_list_of_mapsets(Begins at: 53, Ends at:85)
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 33 | | OK | 33 |
G_add_mapset_to_search_path(Begins at: 219, Ends at:228)
metrics are OK
G_available_mapsets(Begins at: 157, Ends at:209)
LOC: | 53 | * | WARNING | 53 |
G_reset_mapsets(Begins at: 143, Ends at:148)
metrics are OK
G__create_alt_search_path(Begins at: 106, Ends at:114)
metrics are OK
G__mapset_name(Begins at: 36, Ends at:51)
metrics are OK
G__switch_search_path(Begins at: 121, Ends at:136)
metrics are OK
new_mapset(Begins at: 87, Ends at:99)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/parser.c
Class
Item(Begins at: 109, Ends at:114)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
check_an_opt(Begins at: 2201, Ends at:2243)
LOC: | 43 | * | WARNING | 43 |
check_double(Begins at: 2309, Ends at:2345)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
LOC: | 37 | | OK | 37 |
check_int(Begins at: 2245, Ends at:2281)
check_multiple_opts(Begins at: 2457, Ends at:2492)
check_opts(Begins at: 2165, Ends at:2199)
check_overwrite(Begins at: 2495, Ends at:2560)
Complexity: | 12 | * | WARNING | 12 |
check_required(Begins at: 2373, Ends at:2395)
LOC: | 23 | | OK | 23 |
metrics are OK
check_string(Begins at: 2347, Ends at:2371)
contains(Begins at: 2083, Ends at:2091)
metrics are OK
generate_tcl(Begins at: 1815, Ends at:1913)
CalledNBR: | 34 | ** | BABY-MONSTER | 34 |
LOC: | 99 | ** | BABY-MONSTER | 99 |
G_define_flag(Begins at: 176, Ends at:213)
Complexity: | 3 | * | WARNING | 3 |
CalledNBR: | 4 | * | WARNING | 4 |
LOC: | 38 | * | WARNING | 38 |
G_define_module(Begins at: 649, Ends at:662)
metrics are OK
G_define_option(Begins at: 232, Ends at:283)
LOC: | 52 | | OK | 52 |
metrics are OK
G_define_standard_option(Begins at: 312, Ends at:640)
Complexity: | 38 | | OK | 38 |
CalledNBR: | 43 | | OK | 43 |
LOC: | 329 | * | WARNING | 329 |
G_disable_interactive(Begins at: 155, Ends at:160)
Complexity: | 1 | *** | MONSTER | 1 |
CalledNBR: | 0 | *** | MONSTER | 0 |
LOC: | 6 | *** | MONSTER | 6 |
Conclusion: | this function is a MONSTER |
G_gui(Begins at: 1973, Ends at:1988)
metrics are OK
G_gui_tcltk(Begins at: 1918, Ends at:1947)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 12 | | OK | 12 |
LOC: | 30 | | OK | 30 |
metrics are OK
G_gui_wx(Begins at: 1952, Ends at:1964)
CalledNBR: | 6 | * | WARNING | 6 |
G_parser(Begins at: 701, Ends at:955)
Complexity: | 41 | | OK | 41 |
CalledNBR: | 83 | | OK | 83 |
LOC: | 255 | | OK | 255 |
metrics are OK
G_recreate_command(Begins at: 2600, Ends at:2699)
Complexity: | 14 | *** | MONSTER | 14 |
CalledNBR: | 26 | *** | MONSTER | 26 |
LOC: | 100 | *** | MONSTER | 100 |
G_script(Begins at: 1696, Ends at:1808)
Complexity: | 24 | ** | BABY-MONSTER | 24 |
CalledNBR: | 46 | ** | BABY-MONSTER | 46 |
LOC: | 113 | ** | BABY-MONSTER | 113 |
G_tcltk(Begins at: 1993, Ends at:2001)
Complexity: | 3 | *** | MONSTER | 3 |
CalledNBR: | 2 | *** | MONSTER | 2 |
LOC: | 9 | ** | BABY-MONSTER | 9 |
G_usage(Begins at: 1008, Ends at:1179)
Complexity: | 34 | | OK | 34 |
CalledNBR: | 53 | | OK | 53 |
LOC: | 172 | | OK | 172 |
metrics are OK
G_usage_html(Begins at: 1472, Ends at:1691)
Complexity: | 42 | *** | MONSTER | 42 |
CalledNBR: | 85 | *** | MONSTER | 85 |
LOC: | 220 | *** | MONSTER | 220 |
G_usage_xml(Begins at: 1234, Ends at:1467)
Complexity: | 31 | *** | MONSTER | 31 |
CalledNBR: | 87 | *** | MONSTER | 87 |
LOC: | 234 | *** | MONSTER | 234 |
is_option(Begins at: 2093, Ends at:2106)
Complexity: | 4 | *** | MONSTER | 4 |
LOC: | 14 | *** | MONSTER | 14 |
print_escaped_for_html(Begins at: 1213, Ends at:1227)
Complexity: | 4 | * | WARNING | 4 |
print_escaped_for_xml(Begins at: 1189, Ends at:1206)
Complexity: | 7 | | OK | 7 |
LOC: | 18 | | OK | 18 |
metrics are OK
set_flag(Begins at: 2054, Ends at:2078)
CalledNBR: | 4 | *** | MONSTER | 4 |
LOC: | 25 | ** | BABY-MONSTER | 25 |
set_option(Begins at: 2108, Ends at:2163)
Complexity: | 8 | | OK | 8 |
CalledNBR: | 13 | | OK | 13 |
LOC: | 56 | | OK | 56 |
metrics are OK
show(Begins at: 2040, Ends at:2052)
metrics are OK
show_options(Begins at: 2010, Ends at:2038)
CalledNBR: | 11 | | OK | 11 |
split_gisprompt(Begins at: 2562, Ends at:2590)
ParamNBR: | 4 | | OK | 4 |
metrics are OK
split_opts(Begins at: 2397, Ends at:2455)
LOC: | 59 | * | WARNING | 59 |
uses_new_gisprompt(Begins at: 958, Ends at:983)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/percent.c
Function
G_percent(Begins at: 56, Ends at:59)
G_percent2(Begins at: 93, Ends at:137)
LOC: | 45 | * | WARNING | 45 |
G_percent_reset(Begins at: 146, Ends at:152)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/plot.c
Function
edge(Begins at: 661, Ends at:697)
edge_order(Begins at: 723, Ends at:738)
metrics are OK
edge_point(Begins at: 699, Ends at:721)
metrics are OK
fastline(Begins at: 244, Ends at:250)
G_plot_area(Begins at: 542, Ends at:659)
Complexity: | 23 | *** | MONSTER | 23 |
LOC: | 118 | ** | BABY-MONSTER | 118 |
G_plot_fx(Begins at: 811, Ends at:841)
CalledNBR: | 8 | | OK | 8 |
LOC: | 31 | | OK | 31 |
G_plot_line(Begins at: 230, Ends at:233)
G_plot_line2(Begins at: 235, Ends at:238)
G_plot_point(Begins at: 198, Ends at:207)
metrics are OK
G_plot_polygon(Begins at: 412, Ends at:514)
Complexity: | 21 | *** | MONSTER | 21 |
CalledNBR: | 23 | ** | BABY-MONSTER | 23 |
LOC: | 103 | ** | BABY-MONSTER | 103 |
G_plot_where_en(Begins at: 190, Ends at:196)
G_plot_where_xy(Begins at: 168, Ends at:174)
G_setup_fill(Begins at: 136, Ends at:146)
metrics are OK
G_setup_plot(Begins at: 97, Ends at:123)
ParamNBR: | 10 | *** | MONSTER | 10 |
LOC: | 27 | | OK | 27 |
iceil(Begins at: 783, Ends at:791)
metrics are OK
ifloor(Begins at: 773, Ends at:781)
metrics are OK
nearest(Begins at: 389, Ends at:397)
metrics are OK
plot_line(Begins at: 316, Ends at:365)
ParamNBR: | 9 | *** | MONSTER | 9 |
row_dotted_fill(Begins at: 754, Ends at:771)
row_solid_fill(Begins at: 740, Ends at:752)
slowline(Begins at: 258, Ends at:314)
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 57 | * | WARNING | 57 |
Clone analysis:
File :grass/trunk/lib/gis/rhumbline.c
Function
adjust_lat(Begins at: 121, Ends at:129)
metrics are OK
G_begin_rhumbline_equation(Begins at: 57, Ends at:85)
G_rhumbline_lat_from_lon(Begins at: 97, Ends at:105)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/set_window.c
Function
G_get_set_window(Begins at: 30, Ends at:36)
metrics are OK
G_set_window(Begins at: 49, Ends at:152)
LOC: | 104 | ** | BABY-MONSTER | 104 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 02:55:40 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
