[GRASS-QA] GRASS QA: glynn |gisdefs.h debug.c G.h gisinit.c ...| no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 02:33:49 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/gisdefs.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/gis/debug.c
Function
G_debug(Begins at: 46, Ends at:90)
| New Metrics |Old Metrics|
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 45 | * | WARNING | 45 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
G_dump(Begins at: 103, Ends at:156)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 46 | *** | MONSTER | 46 |
LOC: | 54 | * | WARNING | 54 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/gis/G.h
Class
G__(Begins at: 49, Ends at:71)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
fileinfo(Begins at: 17, Ends at:47)
Clone analysis:
File :grass/trunk/lib/gis/gisinit.c
Function
gisinit(Begins at: 114, Ends at:146)
CalledNBR: | 3 | | OK | 3 |
LOC: | 33 | | OK | 33 |
Conclusion: | this function is a OK |
metrics are OK
G__check_gisinit(Begins at: 104, Ends at:111)
Complexity: | 2 | * | WARNING | 2 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 8 | | OK | 8 |
at least 1 values are close to an outlier please consider revising code!
G__gisinit(Begins at: 44, Ends at:72)
Complexity: | 7 | | OK | 7 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 12 | | OK | 12 |
LOC: | 29 | | OK | 29 |
metrics are OK
G__no_gisinit(Begins at: 83, Ends at:94)
Complexity: | 3 | | OK | 3 |
LOC: | 12 | | OK | 12 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/opencell.c
Function
allocate_compress_buf(Begins at: 798, Ends at:815)
LOC: | 18 | | OK | 18 |
metrics are OK
clean_check_raster_name(Begins at: 580, Ends at:609)
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 30 | | OK | 30 |
at least 2 values are close to an outlier please consider revising code!
G_cellvalue_format(Begins at: 500, Ends at:509)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 10 | | OK | 10 |
metrics are OK
G_get_raster_map_type(Begins at: 1020, Ends at:1025)
CalledNBR: | 0 | | OK | 0 |
LOC: | 6 | | OK | 6 |
metrics are OK
G_open_cell_new(Begins at: 399, Ends at:406)
metrics are OK
G_open_cell_new_random(Begins at: 420, Ends at:427)
metrics are OK
G_open_cell_new_uncompressed(Begins at: 439, Ends at:446)
metrics are OK
G_open_cell_old(Begins at: 98, Ends at:118)
Complexity: | 2 | | OK | 2 |
LOC: | 21 | | OK | 21 |
metrics are OK
G_open_fp_cell_new(Begins at: 528, Ends at:548)
metrics are OK
G_open_fp_cell_new_uncompressed(Begins at: 560, Ends at:578)
LOC: | 19 | | OK | 19 |
metrics are OK
G_open_raster_new(Begins at: 1109, Ends at:1116)
metrics are OK
G_open_raster_new_uncompressed(Begins at: 1129, Ends at:1136)
metrics are OK
G_raster_map_is_fp(Begins at: 951, Ends at:969)
CalledNBR: | 7 | | OK | 7 |
metrics are OK
G_raster_map_type(Begins at: 983, Ends at:1007)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 10 | | OK | 10 |
LOC: | 25 | | OK | 25 |
metrics are OK
G_set_cell_format(Begins at: 479, Ends at:491)
LOC: | 13 | | OK | 13 |
metrics are OK
G_set_fp_type(Begins at: 919, Ends at:933)
LOC: | 15 | | OK | 15 |
metrics are OK
G_set_quant_rules(Begins at: 1153, Ends at:1179)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 27 | | OK | 27 |
G_want_histogram(Begins at: 458, Ends at:463)
metrics are OK
G__check_fp_type(Begins at: 1035, Ends at:1087)
Complexity: | 9 | *** | MONSTER | 9 |
CalledNBR: | 24 | *** | MONSTER | 24 |
LOC: | 53 | *** | MONSTER | 53 |
G__open_cell_old(Begins at: 147, Ends at:345)
Complexity: | 24 | ** | BABY-MONSTER | 24 |
CalledNBR: | 50 | *** | MONSTER | 50 |
LOC: | 199 | *** | MONSTER | 199 |
G__open_raster_new(Begins at: 612, Ends at:787)
Complexity: | 20 | | OK | 20 |
CalledNBR: | 66 | | OK | 66 |
LOC: | 176 | | OK | 176 |
metrics are OK
G__reallocate_mask_buf(Begins at: 867, Ends at:881)
metrics are OK
G__reallocate_null_buf(Begins at: 847, Ends at:860)
LOC: | 14 | | OK | 14 |
metrics are OK
G__reallocate_temp_buf(Begins at: 888, Ends at:902)
metrics are OK
G__reallocate_work_buf(Begins at: 824, Ends at:839)
LOC: | 16 | | OK | 16 |
metrics are OK
new_fileinfo(Begins at: 29, Ends at:51)
LOC: | 23 | | OK | 23 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/progrm_nme.c
Function
G_program_name(Begins at: 33, Ends at:36)
LOC: | 4 | | OK | 4 |
metrics are OK
G_set_program_name(Begins at: 38, Ends at:56)
CalledNBR: | 6 | | OK | 6 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/whoami.c
Function
G_whoami(Begins at: 40, Ends at:79)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 40 | | OK | 40 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 02:59:57 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
