[GRASS-QA] GRASS QA: martinl |digit.cpp digit.h undo.cpp | no clones
| 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 02:44:19 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/gui/wxpython/vdigit/digit.cpp
Class
Digit(Begins at: -9999, Ends at:-9999)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 5 | 9 | 0 | 3 |
|OLD Metrics | 1 | 0 | 5 | 9 | 0 | 3 |
Method
Digit(Begins at: 25, Ends at:38)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 14 | | OK | 14 |
Conclusion: | this function is a OK |
metrics are OK
UpdateSettings(Begins at: 57, Ends at:62)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 6 | | OK | 6 |
metrics are OK
~Digit(Begins at: 45, Ends at:50)
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 2 | | OK | 2 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/gui/wxpython/vdigit/digit.h
Class
Digit(Begins at: 9, Ends at:92)
|NEW Metrics | 1 | 0 | 0 | 33 | 0 | 528 |
|OLD Metrics | 1 | 0 | 0 | 33 | 0 | 528 |
Class
_settings(Begins at: 32, Ends at:34)
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
action_meta(Begins at: 22, Ends at:29)
Clone analysis:
File :grass/branches/develbranch_6/gui/wxpython/vdigit/undo.cpp
Class
|NEW Metrics | 1 | 0 | 36 | 80 | 0 | 15 |
|OLD Metrics | 1 | 0 | 36 | 80 | 0 | 15 |
Method
AddActionToChangeset(Begins at: 159, Ends at:188)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 30 | | OK | 30 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
ApplyChangeset(Begins at: 90, Ends at:147)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 58 | * | WARNING | 58 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
FreeChangeset(Begins at: 195, Ends at:210)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 16 | | OK | 16 |
metrics are OK
GetUndoLevel(Begins at: 244, Ends at:247)
LOC: | 4 | | OK | 4 |
metrics are OK
RemoveActionFromChangeset(Begins at: 222, Ends at:237)
CalledNBR: | 7 | | OK | 7 |
Undo(Begins at: 32, Ends at:78)
Complexity: | 11 | * | WARNING | 11 |
LOC: | 47 | * | WARNING | 47 |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 03:10:27 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
