[GRASS-QA] GRASS QA: martinl |digit.cpp digit.h undo.cpp | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 02:46:50 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/gui/wxpython/vdigit/digit.cpp
          Class
Digit(Begins at: -9999, Ends at:-9999)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      5 |      9 |      0 |      3 |
|OLD Metrics |      1 |      0 |      5 |      9 |      0 |      3 |
          Method
Digit(Begins at: 25, Ends at:38)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a            OK           |
metrics are OK
UpdateSettings(Begins at: 57, Ends at:62)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
~Digit(Begins at: 45, Ends at:50)
ParamNBR:     |       0 |       |           OK |         0 |
CalledNBR:    |       2 |       |           OK |         2 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/gui/wxpython/vdigit/digit.h
          Class
Digit(Begins at: 9, Ends at:92)
|NEW Metrics |      1 |      0 |      0 |     33 |      0 |    528 |
|OLD Metrics |      1 |      0 |      0 |     33 |      0 |    528 |
          Class
_settings(Begins at: 32, Ends at:34)
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
action_meta(Begins at: 22, Ends at:29)
Clone analysis:
          File :grass/trunk/gui/wxpython/vdigit/undo.cpp
          Class
|NEW Metrics |      1 |      0 |     36 |     80 |      0 |     15 |
|OLD Metrics |      1 |      0 |     36 |     80 |      0 |     15 |
          Method
AddActionToChangeset(Begins at: 159, Ends at:188)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      30 |       |           OK |        30 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
ApplyChangeset(Begins at: 90, Ends at:147)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      58 |     * |      WARNING |        58 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
FreeChangeset(Begins at: 195, Ends at:210)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
GetUndoLevel(Begins at: 244, Ends at:247)
ParamNBR:     |       0 |     * |      WARNING |         0 |
LOC:          |       4 |       |           OK |         4 |
RemoveActionFromChangeset(Begins at: 222, Ends at:237)
Complexity:   |       4 |     * |      WARNING |         4 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      16 |     * |      WARNING |        16 |
 at least 2 values are close to an outlier please consider revising code!
Undo(Begins at: 32, Ends at:78)
Complexity:   |      11 |       |           OK |        11 |
LOC:          |      47 |       |           OK |        47 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 03:12:57 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
