[GRASS-QA] GRASS QA: glynn |gisdefs.h counter.c datum.c debug.c ...|
no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 03:58:28 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/gisdefs.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/gis/counter.c
File :grass/trunk/lib/gis/datum.c
Function
compare_table_names(Begins at: 195, Ends at:201)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
Conclusion: | this function is a OK |
metrics are OK
G_datum_description(Begins at: 66, Ends at:74)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
LOC: | 9 | | OK | 9 |
metrics are OK
G_datum_ellipsoid(Begins at: 76, Ends at:84)
metrics are OK
G_datum_name(Begins at: 56, Ends at:64)
metrics are OK
G_get_datumparams_from_projinfo(Begins at: 107, Ends at:142)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 36 | | OK | 36 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
G_get_datum_by_name(Begins at: 43, Ends at:54)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 12 | | OK | 12 |
metrics are OK
read_datum_table(Begins at: 144, Ends at:193)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 50 | * | WARNING | 50 |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/gis/debug.c
Function
G_debug(Begins at: 46, Ends at:90)
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 45 | * | WARNING | 45 |
at least 4 values are close to an outlier please consider revising code!
G_dump(Begins at: 103, Ends at:156)
CalledNBR: | 46 | *** | MONSTER | 46 |
LOC: | 54 | * | WARNING | 54 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :grass/trunk/lib/gis/env.c
Function
get_env(Begins at: 182, Ends at:193)
metrics are OK
G_getenv(Begins at: 267, Ends at:276)
CalledNBR: | 3 | | OK | 3 |
LOC: | 10 | | OK | 10 |
metrics are OK
G_getenv2(Begins at: 293, Ends at:302)
metrics are OK
G_get_gisrc_mode(Begins at: 71, Ends at:74)
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
G_setenv(Begins at: 352, Ends at:358)
metrics are OK
G_setenv2(Begins at: 372, Ends at:378)
at least 1 values are close to an outlier please consider revising code!
G_set_gisrc_mode(Begins at: 59, Ends at:62)
metrics are OK
G_unsetenv(Begins at: 420, Ends at:427)
LOC: | 8 | | OK | 8 |
metrics are OK
G_unsetenv2(Begins at: 438, Ends at:445)
metrics are OK
G__create_alt_env(Begins at: 537, Ends at:552)
LOC: | 16 | | OK | 16 |
metrics are OK
G__env_name(Begins at: 476, Ends at:486)
Complexity: | 4 | | OK | 4 |
LOC: | 11 | | OK | 11 |
metrics are OK
G__getenv(Begins at: 312, Ends at:320)
CalledNBR: | 4 | | OK | 4 |
metrics are OK
G__getenv2(Begins at: 331, Ends at:339)
metrics are OK
G__get_gisrc_file(Begins at: 525, Ends at:528)
metrics are OK
G__read_env(Begins at: 495, Ends at:500)
LOC: | 6 | | OK | 6 |
metrics are OK
G__setenv(Begins at: 388, Ends at:393)
metrics are OK
G__setenv2(Begins at: 404, Ends at:409)
G__set_gisrc_file(Begins at: 509, Ends at:516)
metrics are OK
G__switch_env(Begins at: 561, Ends at:576)
metrics are OK
G__write_env(Begins at: 454, Ends at:460)
metrics are OK
open_env(Begins at: 233, Ends at:256)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 24 | | OK | 24 |
metrics are OK
read_env(Begins at: 76, Ends at:110)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 35 | | OK | 35 |
set_env(Begins at: 112, Ends at:165)
Complexity: | 8 | * | WARNING | 8 |
unset_env(Begins at: 167, Ends at:180)
LOC: | 14 | | OK | 14 |
metrics are OK
write_env(Begins at: 195, Ends at:207)
LOC: | 13 | | OK | 13 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/error.c
Function
G_fatal_error(Begins at: 150, Ends at:159)
metrics are OK
G_important_message(Begins at: 119, Ends at:130)
metrics are OK
G_info_format(Begins at: 497, Ends at:514)
LOC: | 18 | | OK | 18 |
metrics are OK
G_message(Begins at: 74, Ends at:85)
metrics are OK
G_set_error_routine(Begins at: 228, Ends at:232)
LOC: | 5 | | OK | 5 |
G_sleep_on_error(Begins at: 210, Ends at:217)
metrics are OK
G_suppress_warnings(Begins at: 194, Ends at:201)
metrics are OK
G_unset_error_routine(Begins at: 242, Ends at:247)
metrics are OK
G_verbose_message(Begins at: 95, Ends at:106)
metrics are OK
G_warning(Begins at: 173, Ends at:185)
metrics are OK
log_error(Begins at: 305, Ends at:338)
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 34 | | OK | 34 |
at least 2 values are close to an outlier please consider revising code!
mail_msg(Begins at: 375, Ends at:392)
metrics are OK
print_error(Begins at: 250, Ends at:303)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 17 | * | WARNING | 17 |
print_sentence(Begins at: 448, Ends at:488)
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 41 | | OK | 41 |
print_word(Begins at: 395, Ends at:445)
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 51 | * | WARNING | 51 |
vfprint_error(Begins at: 57, Ends at:65)
write_error(Begins at: 341, Ends at:372)
ParamNBR: | 5 | * | WARNING | 5 |
LOC: | 32 | | OK | 32 |
Clone analysis:
File :grass/trunk/lib/gis/gdal.c
File :grass/trunk/lib/gis/get_ellipse.c
Function
compare_table_names(Begins at: 255, Ends at:261)
metrics are OK
ellipsoid_table_file(Begins at: 249, Ends at:253)
metrics are OK
get_a_e2_f(Begins at: 208, Ends at:247)
LOC: | 40 | | OK | 40 |
get_ellipsoid_parameters(Begins at: 341, Ends at:406)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 66 | * | WARNING | 66 |
G_ellipsoid_description(Begins at: 202, Ends at:206)
metrics are OK
G_ellipsoid_name(Begins at: 138, Ends at:142)
metrics are OK
G_get_ellipsoid_by_name(Begins at: 110, Ends at:124)
LOC: | 15 | | OK | 15 |
G_get_ellipsoid_parameters(Begins at: 66, Ends at:94)
CalledNBR: | 7 | | OK | 7 |
LOC: | 29 | | OK | 29 |
metrics are OK
G_get_spheroid_by_name(Begins at: 171, Ends at:186)
read_ellipsoid_table(Begins at: 263, Ends at:339)
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 77 | * | WARNING | 77 |
Conclusion: | this function is a BABY-MONSTER |
Clone analysis:
File :grass/trunk/lib/gis/get_window.c
Function
G_get_default_window(Begins at: 115, Ends at:124)
metrics are OK
G_get_window(Begins at: 47, Ends at:100)
G__get_window(Begins at: 126, Ends at:156)
LOC: | 31 | | OK | 31 |
Clone analysis:
File :grass/trunk/lib/gis/gisinit.c
Function
gisinit(Begins at: 114, Ends at:146)
LOC: | 33 | | OK | 33 |
metrics are OK
G__check_gisinit(Begins at: 104, Ends at:111)
Complexity: | 2 | * | WARNING | 2 |
G__gisinit(Begins at: 44, Ends at:72)
Complexity: | 7 | | OK | 7 |
CalledNBR: | 12 | | OK | 12 |
metrics are OK
G__no_gisinit(Begins at: 83, Ends at:94)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/home.c
Function
G_home(Begins at: 32, Ends at:41)
metrics are OK
G__home(Begins at: 43, Ends at:72)
LOC: | 30 | | OK | 30 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/locale.c
Function
G_gettext(Begins at: 53, Ends at:74)
LOC: | 22 | | OK | 22 |
metrics are OK
locale_dir(Begins at: 25, Ends at:41)
LOC: | 17 | | OK | 17 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/mach_name.c
Function
G__machine_name(Begins at: 23, Ends at:40)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/mapset_nme.c
Function
get_list_of_mapsets(Begins at: 53, Ends at:85)
G_add_mapset_to_search_path(Begins at: 219, Ends at:228)
metrics are OK
G_available_mapsets(Begins at: 157, Ends at:209)
LOC: | 53 | * | WARNING | 53 |
G_reset_mapsets(Begins at: 143, Ends at:148)
metrics are OK
G__create_alt_search_path(Begins at: 106, Ends at:114)
metrics are OK
G__mapset_name(Begins at: 36, Ends at:51)
metrics are OK
G__switch_search_path(Begins at: 121, Ends at:136)
metrics are OK
new_mapset(Begins at: 87, Ends at:99)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/opencell.c
Function
allocate_compress_buf(Begins at: 798, Ends at:815)
metrics are OK
clean_check_raster_name(Begins at: 580, Ends at:609)
G_cellvalue_format(Begins at: 500, Ends at:509)
metrics are OK
G_get_raster_map_type(Begins at: 1020, Ends at:1025)
metrics are OK
G_open_cell_new(Begins at: 399, Ends at:406)
metrics are OK
G_open_cell_new_random(Begins at: 420, Ends at:427)
metrics are OK
G_open_cell_new_uncompressed(Begins at: 439, Ends at:446)
metrics are OK
G_open_cell_old(Begins at: 98, Ends at:118)
LOC: | 21 | | OK | 21 |
metrics are OK
G_open_fp_cell_new(Begins at: 528, Ends at:548)
metrics are OK
G_open_fp_cell_new_uncompressed(Begins at: 560, Ends at:578)
LOC: | 19 | | OK | 19 |
metrics are OK
G_open_raster_new(Begins at: 1109, Ends at:1116)
metrics are OK
G_open_raster_new_uncompressed(Begins at: 1129, Ends at:1136)
metrics are OK
G_raster_map_is_fp(Begins at: 951, Ends at:969)
metrics are OK
G_raster_map_type(Begins at: 983, Ends at:1007)
CalledNBR: | 10 | | OK | 10 |
LOC: | 25 | | OK | 25 |
metrics are OK
G_set_cell_format(Begins at: 479, Ends at:491)
metrics are OK
G_set_fp_type(Begins at: 919, Ends at:933)
metrics are OK
G_set_quant_rules(Begins at: 1153, Ends at:1179)
LOC: | 27 | | OK | 27 |
G_want_histogram(Begins at: 458, Ends at:463)
metrics are OK
G__check_fp_type(Begins at: 1035, Ends at:1087)
Complexity: | 9 | *** | MONSTER | 9 |
CalledNBR: | 24 | *** | MONSTER | 24 |
LOC: | 53 | *** | MONSTER | 53 |
G__open_cell_old(Begins at: 147, Ends at:345)
Complexity: | 24 | ** | BABY-MONSTER | 24 |
CalledNBR: | 50 | *** | MONSTER | 50 |
LOC: | 199 | *** | MONSTER | 199 |
G__open_raster_new(Begins at: 612, Ends at:787)
Complexity: | 20 | | OK | 20 |
CalledNBR: | 66 | | OK | 66 |
LOC: | 176 | | OK | 176 |
metrics are OK
G__reallocate_mask_buf(Begins at: 867, Ends at:881)
metrics are OK
G__reallocate_null_buf(Begins at: 847, Ends at:860)
metrics are OK
G__reallocate_temp_buf(Begins at: 888, Ends at:902)
metrics are OK
G__reallocate_work_buf(Begins at: 824, Ends at:839)
metrics are OK
new_fileinfo(Begins at: 29, Ends at:51)
LOC: | 23 | | OK | 23 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/tempfile.c
Function
G_tempfile(Begins at: 47, Ends at:50)
metrics are OK
G__tempfile(Begins at: 62, Ends at:80)
metrics are OK
G__temp_element(Begins at: 90, Ends at:103)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/verbose.c
Function
G_set_verbose(Begins at: 106, Ends at:114)
metrics are OK
G_verbose(Begins at: 45, Ends at:59)
metrics are OK
G_verbose_max(Begins at: 68, Ends at:71)
metrics are OK
G_verbose_min(Begins at: 92, Ends at:95)
metrics are OK
G_verbose_std(Begins at: 80, Ends at:83)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/whoami.c
Function
G_whoami(Begins at: 40, Ends at:79)
CalledNBR: | 8 | | OK | 8 |
Clone analysis:
File :grass/trunk/lib/gis/window_map.c
Function
G_adjust_easting(Begins at: 173, Ends at:182)
metrics are OK
G_adjust_east_longitude(Begins at: 148, Ends at:156)
metrics are OK
G_col_to_easting(Begins at: 242, Ends at:245)
metrics are OK
G_easting_to_col(Begins at: 197, Ends at:202)
metrics are OK
G_northing_to_row(Begins at: 128, Ends at:131)
metrics are OK
G_row_repeat_nomask(Begins at: 343, Ends at:373)
metrics are OK
G_row_to_northing(Begins at: 222, Ends at:225)
metrics are OK
G_window_cols(Begins at: 305, Ends at:310)
metrics are OK
G_window_rows(Begins at: 272, Ends at:277)
metrics are OK
G__create_window_mapping(Begins at: 36, Ends at:113)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
LOC: | 78 | * | WARNING | 78 |
G__init_window(Begins at: 319, Ends at:327)
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/worker.c
File :grass/trunk/raster/r.mapcalc/evaluate.c
Function
allocate_buf(Begins at: 24, Ends at:27)
metrics are OK
begin_evaluate(Begins at: 104, Ends at:107)
metrics are OK
do_evaluate(Begins at: 99, Ends at:102)
Complexity: | 1 | * | WARNING | 1 |
end_evaluate(Begins at: 109, Ends at:112)
metrics are OK
error_handler(Begins at: 243, Ends at:261)
Complexity: | 4 | * | WARNING | 4 |
evaluate(Begins at: 214, Ends at:235)
Complexity: | 8 | | OK | 8 |
metrics are OK
evaluate_binding(Begins at: 207, Ends at:210)
metrics are OK
evaluate_constant(Begins at: 116, Ends at:141)
LOC: | 26 | | OK | 26 |
evaluate_function(Begins at: 157, Ends at:205)
Complexity: | 13 | | OK | 13 |
CalledNBR: | 17 | | OK | 17 |
LOC: | 49 | | OK | 49 |
metrics are OK
evaluate_map(Begins at: 148, Ends at:155)
metrics are OK
evaluate_variable(Begins at: 143, Ends at:146)
metrics are OK
execute(Begins at: 283, Ends at:390)
Complexity: | 17 | | OK | 17 |
CalledNBR: | 23 | | OK | 23 |
LOC: | 108 | | OK | 108 |
metrics are OK
initialize(Begins at: 74, Ends at:95)
metrics are OK
initialize_binding(Begins at: 68, Ends at:72)
metrics are OK
initialize_constant(Begins at: 36, Ends at:39)
metrics are OK
initialize_function(Begins at: 53, Ends at:66)
metrics are OK
initialize_map(Begins at: 46, Ends at:51)
metrics are OK
initialize_variable(Begins at: 41, Ends at:44)
metrics are OK
setup_rand(Begins at: 263, Ends at:281)
Complexity: | 2 | ** | BABY-MONSTER | 2 |
CalledNBR: | 5 | * | WARNING | 5 |
LOC: | 19 | * | WARNING | 19 |
set_buf(Begins at: 29, Ends at:32)
Complexity: | 1 | ** | BABY-MONSTER | 1 |
CalledNBR: | 0 | ** | BABY-MONSTER | 0 |
LOC: | 4 | ** | BABY-MONSTER | 4 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 04:24:35 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
