[GRASS-QA] GRASS QA: glynn |counter.c worker.c evaluate.c map.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 04:03:36 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/gis/counter.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/lib/gis/worker.c
          File :grass/trunk/raster/r.mapcalc/evaluate.c
          Function
allocate_buf(Begins at: 24, Ends at:27)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
begin_evaluate(Begins at: 104, Ends at:107)
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
do_evaluate(Begins at: 99, Ends at:102)
Complexity:   |       1 |     * |      WARNING |         1 |
CalledNBR:    |       0 |       |           OK |         0 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
end_evaluate(Begins at: 109, Ends at:112)
metrics are OK
error_handler(Begins at: 243, Ends at:261)
Complexity:   |       4 |     * |      WARNING |         4 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      19 |       |           OK |        19 |
evaluate(Begins at: 214, Ends at:235)
Complexity:   |       8 |    ** | BABY-MONSTER |         8 |
CalledNBR:    |       7 |     * |      WARNING |         7 |
LOC:          |      22 |     * |      WARNING |        22 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
evaluate_binding(Begins at: 207, Ends at:210)
metrics are OK
evaluate_constant(Begins at: 116, Ends at:141)
Complexity:   |       9 |       |           OK |         9 |
LOC:          |      26 |       |           OK |        26 |
metrics are OK
evaluate_function(Begins at: 157, Ends at:205)
Complexity:   |      13 |     * |      WARNING |        13 |
CalledNBR:    |      17 |       |           OK |        17 |
LOC:          |      49 |       |           OK |        49 |
evaluate_map(Begins at: 148, Ends at:155)
LOC:          |       8 |       |           OK |         8 |
metrics are OK
evaluate_variable(Begins at: 143, Ends at:146)
metrics are OK
execute(Begins at: 283, Ends at:390)
Complexity:   |      17 |       |           OK |        17 |
CalledNBR:    |      23 |       |           OK |        23 |
LOC:          |     108 |       |           OK |       108 |
metrics are OK
initialize(Begins at: 74, Ends at:95)
Complexity:   |       8 |       |           OK |         8 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      22 |       |           OK |        22 |
metrics are OK
initialize_binding(Begins at: 68, Ends at:72)
LOC:          |       5 |       |           OK |         5 |
metrics are OK
initialize_constant(Begins at: 36, Ends at:39)
metrics are OK
initialize_function(Begins at: 53, Ends at:66)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
initialize_map(Begins at: 46, Ends at:51)
Complexity:   |       1 |    ** | BABY-MONSTER |         1 |
CalledNBR:    |       2 |    ** | BABY-MONSTER |         2 |
LOC:          |       6 |    ** | BABY-MONSTER |         6 |
initialize_variable(Begins at: 41, Ends at:44)
metrics are OK
setup_rand(Begins at: 263, Ends at:281)
CalledNBR:    |       5 |       |           OK |         5 |
metrics are OK
set_buf(Begins at: 29, Ends at:32)
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.mapcalc/map.c
          Class
map(Begins at: 49, Ends at:65)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
row_cache(Begins at: 42, Ends at:47)
          Class
sub_cache(Begins at: 35, Ends at:40)
          Function
cache_get(Begins at: 189, Ends at:193)
ParamNBR:     |       4 |       |           OK |         4 |
cache_get_raw(Begins at: 130, Ends at:187)
Complexity:   |       6 |       |           OK |         6 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      58 |       |           OK |        58 |
metrics are OK
cache_release(Begins at: 109, Ends at:128)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      20 |       |           OK |        20 |
metrics are OK
cache_setup(Begins at: 100, Ends at:107)
metrics are OK
cache_sub_init(Begins at: 86, Ends at:98)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
check_output_map(Begins at: 651, Ends at:654)
metrics are OK
close_map(Begins at: 426, Ends at:454)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      29 |       |           OK |        29 |
metrics are OK
close_maps(Begins at: 635, Ends at:647)
Complexity:   |       2 |     * |      WARNING |         2 |
close_output_map(Begins at: 673, Ends at:677)
ParamNBR:     |       1 |    ** | BABY-MONSTER |         1 |
CalledNBR:    |       3 |     * |      WARNING |         3 |
compare_ints(Begins at: 197, Ends at:200)
metrics are OK
copy_cats(Begins at: 686, Ends at:696)
LOC:          |      11 |       |           OK |        11 |
metrics are OK
copy_colors(Begins at: 698, Ends at:708)
copy_history(Begins at: 710, Ends at:719)
LOC:          |      10 |       |           OK |        10 |
metrics are OK
create_history(Begins at: 721, Ends at:761)
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      41 |       |           OK |        41 |
get_map_row(Begins at: 593, Ends at:633)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       7 |     * |      WARNING |         7 |
CalledNBR:    |      15 |       |           OK |        15 |
 at least 2 values are close to an outlier please consider revising code!
init_cats(Begins at: 211, Ends at:222)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |     * |      WARNING |         1 |
LOC:          |      12 |       |           OK |        12 |
init_colors(Begins at: 202, Ends at:209)
metrics are OK
map_type(Begins at: 458, Ends at:484)
Complexity:   |      11 |       |           OK |        11 |
LOC:          |      27 |       |           OK |        27 |
metrics are OK
open_map(Begins at: 486, Ends at:579)
Complexity:   |      27 |       |           OK |        27 |
CalledNBR:    |      19 |       |           OK |        19 |
LOC:          |      94 |       |           OK |        94 |
metrics are OK
open_output_map(Begins at: 656, Ends at:665)
metrics are OK
put_map_row(Begins at: 667, Ends at:671)
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |       5 |     * |      WARNING |         5 |
 at least 4 values are close to an outlier please consider revising code!
read_map(Begins at: 387, Ends at:424)
Complexity:   |      12 |       |           OK |        12 |
ParamNBR:     |       5 |       |           OK |         5 |
LOC:          |      38 |       |           OK |        38 |
metrics are OK
read_row(Begins at: 365, Ends at:369)
ParamNBR:     |       4 |     * |      WARNING |         4 |
setup_map(Begins at: 371, Ends at:385)
CalledNBR:    |       2 |     * |      WARNING |         2 |
LOC:          |      15 |     * |      WARNING |        15 |
setup_maps(Begins at: 581, Ends at:591)
metrics are OK
setup_region(Begins at: 24, Ends at:31)
set_read_row_type(Begins at: 226, Ends at:229)
metrics are OK
translate_from_cats(Begins at: 300, Ends at:363)
CalledNBR:    |      13 |       |           OK |        13 |
LOC:          |      64 |       |           OK |        64 |
metrics are OK
translate_from_colors(Begins at: 224, Ends at:275)
Complexity:   |      17 |   *** |      MONSTER |        17 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      52 |    ** | BABY-MONSTER |        52 |
Conclusion:   | this function is a       MONSTER           |
unopen_output_map(Begins at: 679, Ends at:682)
CalledNBR:    |       1 |     * |      WARNING |         1 |
LOC:          |       4 |     * |      WARNING |         4 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 04:29:44 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
