[GRASS-QA] GRASS QA: neteler |copy_tab.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 04:19:09 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/db/dbmi_client/copy_tab.c
          Function
cmp(Begins at: 21, Ends at:31)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
db_copy_table(Begins at: 403, Ends at:410)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
db_copy_table_by_ints(Begins at: 476, Ends at:484)
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
LOC:          |       9 |       |           OK |         9 |
Conclusion:   | this function is a       MONSTER           |
db_copy_table_select(Begins at: 450, Ends at:458)
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
db_copy_table_where(Begins at: 426, Ends at:434)
db__copy_table(Begins at: 58, Ends at:388)
Complexity:   |      49 |   *** |      MONSTER |        49 |
ParamNBR:     |      11 |   *** |      MONSTER |        11 |
CalledNBR:    |     158 |   *** |      MONSTER |       158 |
LOC:          |     331 |   *** |      MONSTER |       331 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Dec 11 04:45:18 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
