[GRASS-QA] GRASS QA: neteler |copy_tab.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Dec 11 04:21:27 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c
Function
cmp(Begins at: 6, Ends at:16)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a OK |
metrics are OK
db_copy_table(Begins at: 360, Ends at:368)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 9 | | OK | 9 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
db_copy_table_by_ints(Begins at: 417, Ends at:426)
ParamNBR: | 9 | *** | MONSTER | 9 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a MONSTER |
db_copy_table_select(Begins at: 395, Ends at:404)
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
db_copy_table_where(Begins at: 377, Ends at:386)
db__copy_table(Begins at: 31, Ends at:351)
Complexity: | 49 | *** | MONSTER | 49 |
ParamNBR: | 11 | *** | MONSTER | 11 |
CalledNBR: | 145 | *** | MONSTER | 145 |
LOC: | 321 | *** | MONSTER | 321 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Dec 11 04:47:35 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
