[GRASS-QA] GRASS QA: glynn |main.c main.c main.c main.c ...| no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 09:04:06 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/vector/v.db.connect/main.c
Function
main(Begins at: 31, Ends at:325)
| New Metrics |Old Metrics|
Complexity: | 36 | *** | MONSTER | 36 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 130 | *** | MONSTER | 130 |
LOC: | 295 | *** | MONSTER | 295 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/vector/v.lrs/v.lrs.create/main.c
Function
cmp_along(Begins at: 876, Ends at:892)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
main(Begins at: 82, Ends at:874)
Complexity: | 80 | *** | MONSTER | 80 |
CalledNBR: | 271 | *** | MONSTER | 271 |
LOC: | 793 | *** | MONSTER | 793 |
Clone analysis:
File :grass/trunk/vector/v.lrs/v.lrs.label/main.c
Function
cmp_along(Begins at: 525, Ends at:535)
Complexity: | 3 | | OK | 3 |
LOC: | 11 | | OK | 11 |
metrics are OK
main(Begins at: 50, Ends at:523)
Complexity: | 29 | *** | MONSTER | 29 |
CalledNBR: | 180 | *** | MONSTER | 180 |
LOC: | 474 | *** | MONSTER | 474 |
Clone analysis:
File :grass/trunk/vector/v.lrs/v.lrs.segment/main.c
Function
find_line(Begins at: 359, Ends at:378)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 20 | | OK | 20 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
main(Begins at: 43, Ends at:354)
CalledNBR: | 132 | *** | MONSTER | 132 |
LOC: | 312 | *** | MONSTER | 312 |
offset_pt_90(Begins at: 384, Ends at:388)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 5 | | OK | 5 |
Clone analysis:
File :grass/trunk/vector/v.lrs/v.lrs.where/main.c
Function
main(Begins at: 36, Ends at:230)
Complexity: | 17 | ** | BABY-MONSTER | 17 |
CalledNBR: | 80 | *** | MONSTER | 80 |
LOC: | 195 | *** | MONSTER | 195 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 09:30:16 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
