[GRASS-QA] GRASS QA: glynn |display.h raster.h draw2.c raster.c | no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 09:14:22 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/display.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/include/raster.h
File :grass/trunk/lib/display/draw2.c
Class
plane(Begins at: 22, Ends at:25)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
rectangle(Begins at: 9, Ends at:15)
Class
vector(Begins at: 17, Ends at:20)
Function
alloc_dst(Begins at: 47, Ends at:56)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a OK |
metrics are OK
alloc_src(Begins at: 58, Ends at:67)
metrics are OK
box_clip(Begins at: 794, Ends at:810)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
box_clip_ll(Begins at: 812, Ends at:825)
LOC: | 14 | | OK | 14 |
at least 1 values are close to an outlier please consider revising code!
clip_plane(Begins at: 119, Ends at:155)
Complexity: | 4 | | OK | 4 |
LOC: | 37 | | OK | 37 |
clip_polygon_plane(Begins at: 714, Ends at:752)
CalledNBR: | 6 | | OK | 6 |
LOC: | 39 | | OK | 39 |
coerce(Begins at: 192, Ends at:198)
CalledNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
metrics are OK
cull_polygon_plane(Begins at: 629, Ends at:672)
LOC: | 44 | * | WARNING | 44 |
cull_polyline_plane(Begins at: 519, Ends at:562)
dealloc_src(Begins at: 69, Ends at:83)
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 15 | | OK | 15 |
dist_plane(Begins at: 109, Ends at:112)
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
do_clip(Begins at: 157, Ends at:180)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 2 | | OK | 2 |
LOC: | 24 | | OK | 24 |
do_convert(Begins at: 85, Ends at:107)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 23 | | OK | 23 |
do_ll_wrap(Begins at: 231, Ends at:250)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 7 | * | WARNING | 7 |
LOC: | 20 | | OK | 20 |
D_box(Begins at: 894, Ends at:906)
ParamNBR: | 4 | ** | BABY-MONSTER | 4 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 13 | | OK | 13 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
D_box_clip(Begins at: 827, Ends at:836)
D_clip_to_display(Begins at: 289, Ends at:293)
ParamNBR: | 1 | * | WARNING | 1 |
LOC: | 5 | | OK | 5 |
D_clip_to_map(Begins at: 323, Ends at:327)
D_clip_to_screen(Begins at: 305, Ends at:311)
metrics are OK
D_cont(Begins at: 846, Ends at:852)
CalledNBR: | 3 | | OK | 3 |
metrics are OK
D_cont_abs(Begins at: 865, Ends at:868)
metrics are OK
D_cont_abs_clip(Begins at: 466, Ends at:479)
metrics are OK
D_cont_clip(Begins at: 442, Ends at:458)
metrics are OK
D_line(Begins at: 854, Ends at:858)
ParamNBR: | 4 | | OK | 4 |
metrics are OK
D_line_abs(Begins at: 870, Ends at:874)
D_line_abs_clip(Begins at: 481, Ends at:485)
Complexity: | 1 | * | WARNING | 1 |
D_line_clip(Begins at: 460, Ends at:464)
D_line_width(Begins at: 908, Ends at:911)
D_move(Begins at: 838, Ends at:844)
ParamNBR: | 2 | * | WARNING | 2 |
D_move_abs(Begins at: 860, Ends at:863)
D_move_abs_clip(Begins at: 345, Ends at:349)
D_move_clip(Begins at: 339, Ends at:343)
D_polydots(Begins at: 876, Ends at:880)
D_polydots_clip(Begins at: 487, Ends at:517)
Complexity: | 6 | | OK | 6 |
LOC: | 31 | | OK | 31 |
D_polygon(Begins at: 888, Ends at:892)
D_polygon_clip(Begins at: 783, Ends at:792)
D_polygon_cull(Begins at: 703, Ends at:712)
D_polyline(Begins at: 882, Ends at:886)
CalledNBR: | 2 | * | WARNING | 2 |
D_polyline_clip(Begins at: 615, Ends at:627)
CalledNBR: | 4 | * | WARNING | 4 |
D_polyline_cull(Begins at: 593, Ends at:605)
D_set_clip(Begins at: 264, Ends at:277)
euclidify(Begins at: 200, Ends at:229)
CalledNBR: | 7 | | OK | 7 |
LOC: | 30 | | OK | 30 |
metrics are OK
interpolate(Begins at: 114, Ends at:117)
metrics are OK
line_clip(Begins at: 366, Ends at:390)
LOC: | 25 | | OK | 25 |
metrics are OK
line_clip_abs(Begins at: 416, Ends at:440)
metrics are OK
line_clip_ll(Begins at: 392, Ends at:414)
polygon_clip(Begins at: 754, Ends at:781)
CalledNBR: | 11 | | OK | 11 |
LOC: | 28 | | OK | 28 |
polygon_cull(Begins at: 674, Ends at:701)
ParamNBR: | 3 | | OK | 3 |
metrics are OK
polyline_clip(Begins at: 607, Ends at:613)
metrics are OK
polyline_cull(Begins at: 564, Ends at:591)
metrics are OK
shift_angle(Begins at: 187, Ends at:190)
metrics are OK
shift_count(Begins at: 182, Ends at:185)
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/raster/raster.c
Function
init(Begins at: 25, Ends at:40)
CalledNBR: | 8 | | OK | 8 |
LOC: | 16 | | OK | 16 |
metrics are OK
R_begin_scaled_raster(Begins at: 540, Ends at:543)
R_bitmap(Begins at: 557, Ends at:560)
R_box_abs(Begins at: 413, Ends at:416)
R_box_rel(Begins at: 431, Ends at:434)
metrics are OK
R_close_driver(Begins at: 68, Ends at:77)
metrics are OK
R_cont_abs(Begins at: 253, Ends at:256)
metrics are OK
R_cont_rel(Begins at: 275, Ends at:278)
metrics are OK
R_encoding(Begins at: 525, Ends at:528)
metrics are OK
R_end_scaled_raster(Begins at: 552, Ends at:555)
metrics are OK
R_erase(Begins at: 200, Ends at:203)
metrics are OK
R_flush(Begins at: 63, Ends at:66)
metrics are OK
R_font(Begins at: 520, Ends at:523)
metrics are OK
R_font_info(Begins at: 535, Ends at:538)
metrics are OK
R_font_list(Begins at: 530, Ends at:533)
metrics are OK
R_get_num_colors(Begins at: 136, Ends at:139)
metrics are OK
R_get_text_box(Begins at: 506, Ends at:509)
ParamNBR: | 5 | * | WARNING | 5 |
R_line_width(Begins at: 186, Ends at:189)
metrics are OK
R_move_abs(Begins at: 216, Ends at:219)
metrics are OK
R_move_rel(Begins at: 236, Ends at:239)
metrics are OK
R_open_driver(Begins at: 42, Ends at:61)
R_polydots_abs(Begins at: 293, Ends at:296)
R_polydots_rel(Begins at: 313, Ends at:316)
R_polygon_abs(Begins at: 374, Ends at:377)
R_polygon_rel(Begins at: 394, Ends at:397)
R_polyline_abs(Begins at: 334, Ends at:337)
R_polyline_rel(Begins at: 356, Ends at:359)
R_RGB_color(Begins at: 172, Ends at:175)
R_scaled_raster(Begins at: 545, Ends at:550)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
LOC: | 6 | | OK | 6 |
R_screen_bot(Begins at: 116, Ends at:119)
metrics are OK
R_screen_left(Begins at: 88, Ends at:91)
metrics are OK
R_screen_rite(Begins at: 102, Ends at:105)
metrics are OK
R_screen_top(Begins at: 131, Ends at:134)
metrics are OK
R_set_window(Begins at: 469, Ends at:472)
R_standard_color(Begins at: 153, Ends at:156)
metrics are OK
R_text(Begins at: 484, Ends at:487)
metrics are OK
R_text_rotation(Begins at: 451, Ends at:454)
metrics are OK
R_text_size(Begins at: 446, Ends at:449)
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 09:40:32 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
