[GRASS-QA] GRASS QA: glynn |null_val.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 09:32:00 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/gis/null_val.c
          Function
EmbedGivenNulls(Begins at: 63, Ends at:97)
              |          New Metrics           |Old Metrics|
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      35 |       |           OK |        35 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
G_insert_c_null_values(Begins at: 547, Ends at:550)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
 at least 1 values are close to an outlier please consider revising code!
G_insert_d_null_values(Begins at: 603, Ends at:606)
G_insert_f_null_values(Begins at: 575, Ends at:578)
G_insert_null_values(Begins at: 518, Ends at:522)
LOC:          |       5 |       |           OK |         5 |
G_is_c_null_value(Begins at: 377, Ends at:395)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      19 |       |           OK |        19 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_is_d_null_value(Begins at: 468, Ends at:486)
metrics are OK
G_is_f_null_value(Begins at: 428, Ends at:446)
metrics are OK
G_is_null_value(Begins at: 340, Ends at:356)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      17 |       |           OK |        17 |
G_set_c_null_value(Begins at: 237, Ends at:256)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      20 |       |           OK |        20 |
metrics are OK
G_set_d_null_value(Begins at: 295, Ends at:314)
metrics are OK
G_set_f_null_value(Begins at: 266, Ends at:285)
metrics are OK
G_set_null_value(Begins at: 207, Ends at:227)
LOC:          |      21 |       |           OK |        21 |
G__check_null_bit(Begins at: 617, Ends at:637)
Complexity:   |       2 |       |           OK |         2 |
G__convert_01_flags(Begins at: 702, Ends at:730)
LOC:          |      29 |       |           OK |        29 |
G__convert_flags_01(Begins at: 741, Ends at:766)
LOC:          |      26 |       |           OK |        26 |
G__init_null_bits(Begins at: 776, Ends at:798)
LOC:          |      23 |       |           OK |        23 |
metrics are OK
G__init_null_patterns(Begins at: 131, Ends at:171)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      41 |       |           OK |        41 |
metrics are OK
G__set_flags_from_01_random(Begins at: 653, Ends at:691)
ParamNBR:     |       5 |     * |      WARNING |         5 |
LOC:          |      39 |       |           OK |        39 |
G__set_null_value(Begins at: 185, Ends at:196)
LOC:          |      12 |       |           OK |        12 |
InitError(Begins at: 108, Ends at:118)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Dec 11 09:58:10 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
