[GRASS-QA] GRASS QA: glynn |gisdefs.h closecell.c gdal.c opencell.c
...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 09:35:26 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/gisdefs.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/gis/closecell.c
Function
close_new(Begins at: 159, Ends at:392)
| New Metrics |Old Metrics|
Complexity: | 32 | *** | MONSTER | 32 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 74 | *** | MONSTER | 74 |
LOC: | 234 | *** | MONSTER | 234 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
close_old(Begins at: 124, Ends at:157)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 34 | | OK | 34 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
G_close_cell(Begins at: 79, Ends at:89)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a OK |
metrics are OK
G_unopen_cell(Begins at: 112, Ends at:122)
metrics are OK
G__write_fp_format(Begins at: 395, Ends at:424)
Complexity: | 4 | | OK | 4 |
LOC: | 30 | | OK | 30 |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/gis/gdal.c
File :grass/trunk/lib/gis/opencell.c
Function
allocate_compress_buf(Begins at: 798, Ends at:815)
CalledNBR: | 3 | | OK | 3 |
LOC: | 18 | | OK | 18 |
metrics are OK
clean_check_raster_name(Begins at: 580, Ends at:609)
ParamNBR: | 3 | * | WARNING | 3 |
at least 2 values are close to an outlier please consider revising code!
G_cellvalue_format(Begins at: 500, Ends at:509)
LOC: | 10 | | OK | 10 |
metrics are OK
G_get_raster_map_type(Begins at: 1020, Ends at:1025)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 6 | | OK | 6 |
metrics are OK
G_open_cell_new(Begins at: 399, Ends at:406)
LOC: | 8 | | OK | 8 |
metrics are OK
G_open_cell_new_random(Begins at: 420, Ends at:427)
metrics are OK
G_open_cell_new_uncompressed(Begins at: 439, Ends at:446)
metrics are OK
G_open_cell_old(Begins at: 98, Ends at:118)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 21 | | OK | 21 |
metrics are OK
G_open_fp_cell_new(Begins at: 528, Ends at:548)
metrics are OK
G_open_fp_cell_new_uncompressed(Begins at: 560, Ends at:578)
LOC: | 19 | | OK | 19 |
metrics are OK
G_open_raster_new(Begins at: 1109, Ends at:1116)
metrics are OK
G_open_raster_new_uncompressed(Begins at: 1129, Ends at:1136)
metrics are OK
G_raster_map_is_fp(Begins at: 951, Ends at:969)
CalledNBR: | 7 | | OK | 7 |
metrics are OK
G_raster_map_type(Begins at: 983, Ends at:1007)
CalledNBR: | 10 | * | WARNING | 10 |
LOC: | 25 | | OK | 25 |
G_set_cell_format(Begins at: 479, Ends at:491)
LOC: | 13 | | OK | 13 |
metrics are OK
G_set_fp_type(Begins at: 919, Ends at:933)
LOC: | 15 | | OK | 15 |
metrics are OK
G_set_quant_rules(Begins at: 1153, Ends at:1179)
Complexity: | 6 | | OK | 6 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 27 | | OK | 27 |
metrics are OK
G_want_histogram(Begins at: 458, Ends at:463)
Complexity: | 1 | * | WARNING | 1 |
G__check_fp_type(Begins at: 1035, Ends at:1087)
Complexity: | 9 | | OK | 9 |
CalledNBR: | 24 | | OK | 24 |
LOC: | 53 | | OK | 53 |
metrics are OK
G__open_cell_old(Begins at: 147, Ends at:345)
Complexity: | 24 | * | WARNING | 24 |
CalledNBR: | 50 | ** | BABY-MONSTER | 50 |
LOC: | 199 | * | WARNING | 199 |
Conclusion: | this function is a BABY-MONSTER |
G__open_raster_new(Begins at: 612, Ends at:787)
Complexity: | 20 | *** | MONSTER | 20 |
CalledNBR: | 66 | *** | MONSTER | 66 |
LOC: | 176 | *** | MONSTER | 176 |
G__reallocate_mask_buf(Begins at: 867, Ends at:881)
Complexity: | 3 | ** | BABY-MONSTER | 3 |
CalledNBR: | 3 | *** | MONSTER | 3 |
LOC: | 15 | *** | MONSTER | 15 |
G__reallocate_null_buf(Begins at: 847, Ends at:860)
LOC: | 14 | | OK | 14 |
metrics are OK
G__reallocate_temp_buf(Begins at: 888, Ends at:902)
metrics are OK
G__reallocate_work_buf(Begins at: 824, Ends at:839)
LOC: | 16 | | OK | 16 |
metrics are OK
new_fileinfo(Begins at: 29, Ends at:51)
LOC: | 23 | | OK | 23 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/put_row.c
Function
adjust(Begins at: 284, Ends at:301)
check_open(Begins at: 245, Ends at:275)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 31 | | OK | 31 |
convert_and_write_df(Begins at: 809, Ends at:822)
metrics are OK
convert_and_write_di(Begins at: 869, Ends at:882)
metrics are OK
convert_and_write_fd(Begins at: 839, Ends at:852)
metrics are OK
convert_and_write_fi(Begins at: 854, Ends at:867)
metrics are OK
convert_and_write_id(Begins at: 824, Ends at:837)
metrics are OK
convert_and_write_if(Begins at: 794, Ends at:807)
metrics are OK
convert_double(Begins at: 401, Ends at:425)
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
convert_float(Begins at: 375, Ends at:399)
convert_int(Begins at: 483, Ends at:524)
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 42 | * | WARNING | 42 |
count_bytes(Begins at: 526, Ends at:536)
count_run(Begins at: 556, Ends at:569)
G_put_c_raster_row(Begins at: 228, Ends at:231)
LOC: | 4 | | OK | 4 |
metrics are OK
G_put_d_raster_row(Begins at: 238, Ends at:241)
metrics are OK
G_put_f_raster_row(Begins at: 233, Ends at:236)
metrics are OK
G_put_map_row(Begins at: 210, Ends at:221)
LOC: | 12 | | OK | 12 |
metrics are OK
G_put_map_row_random(Begins at: 170, Ends at:192)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 5 | | OK | 5 |
G_put_raster_row(Begins at: 223, Ends at:226)
G_zeros_r_nulls(Begins at: 162, Ends at:168)
LOC: | 7 | | OK | 7 |
metrics are OK
G__open_null_write(Begins at: 748, Ends at:764)
LOC: | 17 | | OK | 17 |
metrics are OK
G__put_null_value_row(Begins at: 194, Ends at:208)
metrics are OK
G__write_data(Begins at: 319, Ends at:330)
G__write_data_compressed(Begins at: 332, Ends at:343)
G__write_null_bits(Begins at: 766, Ends at:786)
put_data(Begins at: 610, Ends at:684)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 75 | * | WARNING | 75 |
put_fp_data(Begins at: 431, Ends at:475)
Complexity: | 12 | * | WARNING | 12 |
LOC: | 45 | * | WARNING | 45 |
put_null_data(Begins at: 706, Ends at:746)
LOC: | 41 | | OK | 41 |
put_raster_data(Begins at: 692, Ends at:698)
put_raster_row(Begins at: 886, Ends at:931)
Complexity: | 8 | | OK | 8 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 46 | | OK | 46 |
rle_compress(Begins at: 571, Ends at:595)
same(Begins at: 551, Ends at:554)
seek_random(Begins at: 347, Ends at:358)
ParamNBR: | 3 | | OK | 3 |
metrics are OK
set_file_pointer(Begins at: 362, Ends at:367)
ParamNBR: | 2 | * | WARNING | 2 |
trim_bytes(Begins at: 538, Ends at:549)
ParamNBR: | 4 | | OK | 4 |
metrics are OK
write_error(Begins at: 303, Ends at:315)
zlib_compress(Begins at: 597, Ends at:606)
LOC: | 10 | * | WARNING | 10 |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/raster/r.external.out/main.c
____________________________________________
Threshold grass key metrics values at Thu Dec 11 10:01:37 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
