[GRASS-QA] GRASS QA: martinl |areas.c lines.c main.c parse.c ...| no
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 09:45:19 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/vector/v.to.db/areas.c
Function
read_areas(Begins at: 15, Ends at:78)
| New Metrics |Old Metrics|
Complexity: | 15 | ** | BABY-MONSTER | 15 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 64 | * | WARNING | 64 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/vector/v.to.db/lines.c
Function
read_lines(Begins at: 57, Ends at:271)
Complexity: | 35 | *** | MONSTER | 35 |
CalledNBR: | 54 | *** | MONSTER | 54 |
LOC: | 215 | *** | MONSTER | 215 |
Conclusion: | this function is a MONSTER |
read_side_cats(Begins at: 10, Ends at:50)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 41 | | OK | 41 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/vector/v.to.db/main.c
Function
main(Begins at: 25, Ends at:100)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 29 | ** | BABY-MONSTER | 29 |
LOC: | 76 | * | WARNING | 76 |
Clone analysis:
File :grass/trunk/vector/v.to.db/parse.c
Function
match(Begins at: 228, Ends at:238)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 11 | | OK | 11 |
at least 1 values are close to an outlier please consider revising code!
parse_command_line(Begins at: 11, Ends at:170)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 48 | *** | MONSTER | 48 |
LOC: | 160 | *** | MONSTER | 160 |
parse_option(Begins at: 192, Ends at:226)
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 35 | | OK | 35 |
parse_units(Begins at: 172, Ends at:190)
CalledNBR: | 6 | | OK | 6 |
LOC: | 19 | | OK | 19 |
Clone analysis:
File :grass/trunk/vector/v.to.db/query.c
Function
query(Begins at: 9, Ends at:189)
Complexity: | 29 | *** | MONSTER | 29 |
CalledNBR: | 64 | *** | MONSTER | 64 |
LOC: | 181 | *** | MONSTER | 181 |
Clone analysis:
File :grass/trunk/vector/v.to.db/report.c
Function
print_stat(Begins at: 172, Ends at:192)
LOC: | 21 | | OK | 21 |
report(Begins at: 5, Ends at:170)
Complexity: | 55 | *** | MONSTER | 55 |
CalledNBR: | 58 | *** | MONSTER | 58 |
LOC: | 166 | *** | MONSTER | 166 |
Clone analysis:
File :grass/trunk/vector/v.to.db/update.c
Function
srch(Begins at: 239, Ends at:249)
CalledNBR: | 0 | | OK | 0 |
Conclusion: | this function is a OK |
metrics are OK
update(Begins at: 9, Ends at:237)
Complexity: | 56 | *** | MONSTER | 56 |
CalledNBR: | 50 | *** | MONSTER | 50 |
LOC: | 229 | *** | MONSTER | 229 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 10:11:30 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
