[GRASS-QA] GRASS QA: martinl |sindex.c main.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 09:48:08 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/vector/Vlib/sindex.c
Function
Vect_build_sidx_from_topo(Begins at: 145, Ends at:240)
| New Metrics |Old Metrics|
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 96 | ** | BABY-MONSTER | 96 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
Vect_build_spatial_index(Begins at: 124, Ends at:134)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a OK |
metrics are OK
Vect_spatial_index_add_item(Begins at: 66, Ends at:79)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 14 | | OK | 14 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Vect_spatial_index_del_item(Begins at: 89, Ends at:110)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 22 | | OK | 22 |
metrics are OK
Vect_spatial_index_destroy(Begins at: 50, Ends at:55)
ParamNBR: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
metrics are OK
Vect_spatial_index_init(Begins at: 34, Ends at:39)
metrics are OK
Vect_spatial_index_select(Begins at: 259, Ends at:279)
LOC: | 21 | | OK | 21 |
_add_item(Begins at: 244, Ends at:248)
CalledNBR: | 1 | | OK | 1 |
LOC: | 5 | | OK | 5 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/vector/v.select/main.c
Function
add_aarea(Begins at: 27, Ends at:55)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 29 | | OK | 29 |
line_overlap_area(Begins at: 59, Ends at:105)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 47 | * | WARNING | 47 |
at least 4 values are close to an outlier please consider revising code!
main(Begins at: 107, Ends at:518)
Complexity: | 52 | *** | MONSTER | 52 |
CalledNBR: | 121 | *** | MONSTER | 121 |
LOC: | 412 | *** | MONSTER | 412 |
Conclusion: | this function is a MONSTER |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 10:14:19 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
