[GRASS-QA] GRASS QA: glynn |cairodriver.h Graph.c read.c read_xid.c
...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 18 16:52:08 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/cairodriver/cairodriver.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/cairodriver/Graph.c
Function
Cairo_Graph_close(Begins at: 236, Ends at:250)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 15 | | OK | 15 |
Conclusion: | this function is a OK |
metrics are OK
Cairo_Graph_set(Begins at: 195, Ends at:234)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 40 | | OK | 40 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
ends_with(Begins at: 298, Ends at:305)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 8 | | OK | 8 |
metrics are OK
init_cairo(Begins at: 252, Ends at:295)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 44 | * | WARNING | 44 |
at least 2 values are close to an outlier please consider revising code!
init_file(Begins at: 100, Ends at:193)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
CalledNBR: | 25 | ** | BABY-MONSTER | 25 |
LOC: | 94 | ** | BABY-MONSTER | 94 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
init_xlib(Begins at: 45, Ends at:97)
Complexity: | 7 | * | WARNING | 7 |
LOC: | 53 | * | WARNING | 53 |
at least 3 values are close to an outlier please consider revising code!
map_file(Begins at: 307, Ends at:333)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 27 | | OK | 27 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/cairodriver/read.c
Function
cairo_read_image(Begins at: 3, Ends at:39)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 37 | | OK | 37 |
Clone analysis:
File :grass/trunk/lib/cairodriver/read_xid.c
File :grass/trunk/lib/cairodriver/write.c
Function
cairo_write_image(Begins at: 8, Ends at:43)
Complexity: | 8 | * | WARNING | 8 |
LOC: | 36 | | OK | 36 |
Clone analysis:
File :grass/trunk/lib/cairodriver/write_xid.c
____________________________________________
Threshold grass key metrics values at Thu Dec 18 17:07:22 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
