[GRASS-QA] GRASS QA: glynn |main.c cairodriver.h Graph.c read.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Dec 19 11:53:58 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/general/g.cairocomp/main.c
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/lib/cairodriver/cairodriver.h
          File :grass/trunk/lib/cairodriver/Graph.c
          Function
Cairo_Graph_close(Begins at: 236, Ends at:250)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      15 |       |           OK |        15 |
Conclusion:   | this function is a            OK           |
metrics are OK
Cairo_Graph_set(Begins at: 195, Ends at:234)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      40 |       |           OK |        40 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
ends_with(Begins at: 298, Ends at:305)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
init_cairo(Begins at: 252, Ends at:295)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      44 |     * |      WARNING |        44 |
 at least 2 values are close to an outlier please consider revising code!
init_file(Begins at: 100, Ends at:193)
Complexity:   |      20 |    ** | BABY-MONSTER |        20 |
CalledNBR:    |      25 |    ** | BABY-MONSTER |        25 |
LOC:          |      94 |    ** | BABY-MONSTER |        94 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
init_xlib(Begins at: 45, Ends at:97)
Complexity:   |       7 |     * |      WARNING |         7 |
LOC:          |      53 |     * |      WARNING |        53 |
 at least 3 values are close to an outlier please consider revising code!
map_file(Begins at: 307, Ends at:333)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      27 |       |           OK |        27 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/cairodriver/read.c
          Function
cairo_read_image(Begins at: 3, Ends at:39)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      37 |       |           OK |        37 |
Clone analysis:
          File :grass/trunk/lib/cairodriver/read_xid.c
          File :grass/trunk/lib/cairodriver/write.c
          Function
cairo_write_image(Begins at: 8, Ends at:43)
Complexity:   |       8 |     * |      WARNING |         8 |
LOC:          |      36 |       |           OK |        36 |
Clone analysis:
          File :grass/trunk/lib/cairodriver/write_xid.c
____________________________________________
Threshold grass key metrics values at Fri Dec 19 12:09:22 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
