[GRASS-QA] GRASS QA: neteler |io.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Dec 31 00:01:14 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.flow/io.c
Function
close_files(Begins at: 173, Ends at:187)
| New Metrics |Old Metrics|
Complexity: | 4 | | OK | 4 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 15 | | OK | 15 |
Conclusion: | this function is a OK |
metrics are OK
open_existing_cell_file(Begins at: 58, Ends at:69)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 12 | | OK | 12 |
metrics are OK
open_output_files(Begins at: 156, Ends at:171)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 16 | | OK | 16 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
open_segment_file(Begins at: 128, Ends at:154)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 27 | | OK | 27 |
at least 3 values are close to an outlier please consider revising code!
read_input_files(Begins at: 71, Ends at:126)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 56 | * | WARNING | 56 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
tmp_name(Begins at: 41, Ends at:54)
CalledNBR: | 3 | | OK | 3 |
LOC: | 14 | | OK | 14 |
metrics are OK
write_density_file(Begins at: 189, Ends at:226)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 23 | ** | BABY-MONSTER | 23 |
LOC: | 38 | | OK | 38 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Dec 31 00:17:17 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
