[GRASS-QA] GRASS QA: neteler |error.c percent.c | no clones | 0
	monsters |0 warnings
    soccerlab.info at gmail.com
    Wed Nov 12 02:17:51 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/gis/error.c
          Function
G_fatal_error(Begins at: 150, Ends at:159)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_important_message(Begins at: 119, Ends at:130)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      12 |       |           OK |        12 |
metrics are OK
G_info_format(Begins at: 497, Ends at:514)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
G_message(Begins at: 74, Ends at:85)
metrics are OK
G_set_error_routine(Begins at: 228, Ends at:232)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       5 |       |           OK |         5 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
G_sleep_on_error(Begins at: 210, Ends at:217)
LOC:          |       8 |       |           OK |         8 |
metrics are OK
G_suppress_warnings(Begins at: 194, Ends at:201)
metrics are OK
G_unset_error_routine(Begins at: 242, Ends at:247)
LOC:          |       6 |       |           OK |         6 |
metrics are OK
G_verbose_message(Begins at: 95, Ends at:106)
metrics are OK
G_warning(Begins at: 173, Ends at:185)
LOC:          |      13 |       |           OK |        13 |
metrics are OK
log_error(Begins at: 305, Ends at:338)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      34 |       |           OK |        34 |
 at least 2 values are close to an outlier please consider revising code!
mail_msg(Begins at: 375, Ends at:392)
Complexity:   |       3 |       |           OK |         3 |
metrics are OK
print_error(Begins at: 250, Ends at:303)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      54 |     * |      WARNING |        54 |
 at least 3 values are close to an outlier please consider revising code!
print_sentence(Begins at: 448, Ends at:488)
Complexity:   |       8 |     * |      WARNING |         8 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      41 |       |           OK |        41 |
print_word(Begins at: 395, Ends at:445)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      51 |     * |      WARNING |        51 |
vfprint_error(Begins at: 57, Ends at:65)
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       9 |       |           OK |         9 |
write_error(Begins at: 341, Ends at:372)
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      32 |       |           OK |        32 |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/gis/percent.c
          Function
G_percent(Begins at: 56, Ends at:59)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
G_percent2(Begins at: 93, Ends at:137)
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      45 |     * |      WARNING |        45 |
G_percent_reset(Begins at: 146, Ends at:152)
LOC:          |       7 |       |           OK |         7 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Nov 12 02:37:42 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
