[GRASS-QA] GRASS QA: neteler |error.c percent.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Wed Nov 12 02:22:29 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/gis/error.c
Function
G_fatal_error(Begins at: 150, Ends at:159)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a OK |
metrics are OK
G_important_message(Begins at: 119, Ends at:130)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 12 | | OK | 12 |
metrics are OK
G_info_format(Begins at: 497, Ends at:514)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 18 | | OK | 18 |
metrics are OK
G_message(Begins at: 74, Ends at:85)
metrics are OK
G_set_error_routine(Begins at: 228, Ends at:232)
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 5 | | OK | 5 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
G_sleep_on_error(Begins at: 210, Ends at:217)
LOC: | 8 | | OK | 8 |
metrics are OK
G_suppress_warnings(Begins at: 194, Ends at:201)
metrics are OK
G_unset_error_routine(Begins at: 242, Ends at:247)
LOC: | 6 | | OK | 6 |
metrics are OK
G_verbose_message(Begins at: 95, Ends at:106)
metrics are OK
G_warning(Begins at: 173, Ends at:185)
LOC: | 13 | | OK | 13 |
metrics are OK
log_error(Begins at: 305, Ends at:338)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 34 | | OK | 34 |
at least 2 values are close to an outlier please consider revising code!
mail_msg(Begins at: 375, Ends at:392)
Complexity: | 3 | | OK | 3 |
metrics are OK
print_error(Begins at: 250, Ends at:303)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 54 | * | WARNING | 54 |
at least 3 values are close to an outlier please consider revising code!
print_sentence(Begins at: 448, Ends at:488)
Complexity: | 8 | * | WARNING | 8 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 41 | | OK | 41 |
print_word(Begins at: 395, Ends at:445)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 4 | * | WARNING | 4 |
LOC: | 51 | * | WARNING | 51 |
vfprint_error(Begins at: 57, Ends at:65)
CalledNBR: | 2 | | OK | 2 |
LOC: | 9 | | OK | 9 |
write_error(Begins at: 341, Ends at:372)
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 32 | | OK | 32 |
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/lib/gis/percent.c
Function
G_percent(Begins at: 56, Ends at:59)
CalledNBR: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
G_percent2(Begins at: 93, Ends at:137)
CalledNBR: | 7 | | OK | 7 |
LOC: | 45 | * | WARNING | 45 |
G_percent_reset(Begins at: 146, Ends at:152)
LOC: | 7 | | OK | 7 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Nov 12 02:42:20 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
